Third Brake Light Idea
#16
Posted 09 January 2012 - 10:17 AM
#17
Posted 09 January 2012 - 10:23 AM
#18
Posted 09 January 2012 - 10:24 AM
What about In between the window rubber and roof lip? CBS-online do some pretty thin led strips and you will only need a little hole due to the wires been thin? Think I might put mine their now will post a pic when it's in.
That sounds like a good idea, I'd certainly like to see the pictures when it's done!!
#19
Posted 09 January 2012 - 11:52 AM
#20
Posted 09 January 2012 - 12:10 PM
I've always been reluctant to fit one at the top of the rear screen (dispite it probably being the most effective place to put it), as the top of the rear screen tends to be the main bit that you see through in the rear view mirror. Fitting a brake light there would therefore obscure rear vision, but this looks to be a small slimline unit that might not therefore cause too much of an issue.
#21
Posted 09 January 2012 - 12:36 PM
I had the same consideration regarding top or bottom of the screen when I fitted mine. Top puts the light straight in the drivers line of sight, but bottom still typically clears the bonnet of the car behind in all but the case of 4x4s. I think that in the ten years that these lights have been mandatory, drivers have been conditioned to look centrally for the brake light, and not to the clusters at all. With that in mind, any position central from the middle of the car up is going to be advantageous.
#22
Posted 09 January 2012 - 12:51 PM
#23
Posted 09 January 2012 - 12:52 PM
#24
Posted 09 January 2012 - 01:03 PM
You could try something like this, at least if it isn't suitable you've only spent £2.80
Or if you're willing to wait for a week or two for postage, there's an ungodly amount of 12v red led strips in china for just over £1
http://www.ebay.co.u...=item336b2c5c9e
I've had a few things from china on ebay and they have generally been pretty good, and those that haven't worked I've got a full refund without having to send the part back!
#25
Posted 09 January 2012 - 01:28 PM
It doesn't look much in the photograph but my third brake light is really quite bright.
Mine is near same as this one as it looks like mine where its adjustable for tilt to. I found right away after fitting that peeps did not appear to be getting to close when coming to a stop, in the dark it does not light up rear window to much either, in future was even thinking of putting 2 in one each side in top window maybe a bit ott but anything to stop another rear end!!!
Edited by bunch1980, 09 January 2012 - 01:29 PM.
#26
Posted 09 January 2012 - 02:02 PM
http://www.ebay.co.uk/itm/LED-Car-Strip-Under-Light-Neon-Footwell-Flexible-Red-/200668018157?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2eb8bef5ed
http://www.ebay.co.uk/itm/Flexible-Red-15-SMD-LED-Bulb-Waterproof-Light-Strip-12V-/220841401502?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item336b2c5c9e
I'm going to try the second link I think, good find, its water proof and says internal and external and from the looks of it you could fit it anywhere.
#27
Posted 09 January 2012 - 02:25 PM
#28
Posted 09 January 2012 - 02:43 PM
I've tried strips of surface mounted LEDs but they're no good for brake lights. They have no reflector or diffuser which means you have a row of bright, but very small red lights which is difficult to see in daylight. The viewing angle is also very limited with most surface mounted LEDs.there are loads of them if you search 12v red led strip including worldwide results and sort by price + p&p lowest first there might be some you prefer. as long as they have a few thousand feedback and over 98% you should be fine.
#29
Posted 09 January 2012 - 03:47 PM
This looks like it could be a good cheap and effective solution for sticking to the inside of the top of the rear screen.
http://www.cbsonline..._Light_LEDSTRIP
OK scrap that idea!! I've just spoke to the supplier & apparently the self adhesive is on the back of the strip, meaning it's to be stuck to the outside!!
Edited by AVV IT, 09 January 2012 - 03:47 PM.
#30
Posted 09 January 2012 - 03:49 PM
That looks quite good and doesn't look too out of place on a classic either? Where did you get it from & how does it attach?
