Extending Power Band
#16
Posted 20 February 2012 - 03:49 PM
What's the ignition system. Has it been on the rollers to check fuelling & timing. It's in about the right ball park for points bounce.
#17
Posted 20 February 2012 - 03:51 PM
Points bounce? I have never heard of that, always learning!!
#18
Posted 20 February 2012 - 04:15 PM
It still seems a tad low for maximum rpm, does it fair better when it's doing less work - through the gears, downhill...?
#19
Posted 20 February 2012 - 04:23 PM
How do you mean, how does it fair?
#20
Posted 20 February 2012 - 04:43 PM
What he means is does it pull past 6k in the gears (1st, 2nd & 3rd)
I want to extend the power band of my modified 1275. At just over 6k it looses all power and really falls off cam.
Basically no, even trying to keep it going past 6k rpm to get into the power band in the next gear is impossible. It really gives up at over 6k
#21
Posted 20 February 2012 - 04:48 PM
If it needs "X" amount of HP to drive it at a certain speed it will by like hitting a wall if that's all the power you have when you get there.
A lower gear, tail wind, or downhill road would take you to higher rpm without any significant drop in acceleration, but if it was down to internal losses or other limitation of the engine it would bog down much the same at the critical rpm.
#22
Posted 20 February 2012 - 04:56 PM
Not only that but how quickly does the acceleration tail off?
It tails off very fast. I would describe it as a clutch slip? If that makes sense? Just can't go anymore.. It trys but nothing there to pull. Which makes sense with what you saying you need X amount of power to go Y amount of speed.
So, the camshaft is doing its best with the components it has around it. The limitation would be head, and being the most restrictive in regard to more power?
#23
Posted 20 February 2012 - 05:02 PM
Does it have a large bore LCB?
Was the CAM timing done with a vernier wheel
#24
Posted 20 February 2012 - 05:05 PM
It is a Maniflow LCB. (not the stage 2 one though)
Yes Cam timed into 106degrees. Duplex timing chain.
#25
Posted 20 February 2012 - 05:11 PM
The same with the head.
to be honest 77 ponies does not sound too much off the mark for that spec.
#26
Posted 20 February 2012 - 05:16 PM
#27
Posted 20 February 2012 - 05:17 PM
The answer seems no, and the head needs more work to let more horses free.
#28
Posted 20 February 2012 - 05:26 PM
This is just thinking aloud really - if the gas velocities somewhere are approaching supersonic at that 6k rpm it will be like hitting a wall. The valve seats would probably be the most likely suspect.
Another thought, what plug gap are you running? As the rpm goes up there's less dwell for the coil to recharge itself, perhaps it can't fire across your plug gaps above that rpm? I wouldn't really expect it to be a problem at 6k, but it'd be easy enough to try reducing the gap a little.
#29
Posted 20 February 2012 - 06:46 PM
I doubt the 276 is the weak link. Are you sure exhaust is clear?
#30
Posted 20 February 2012 - 07:33 PM
So, can anyone get a 276 over 6k?
