Coolant Gone After Head Gasket Replaced.
#16
Posted 26 February 2012 - 08:17 AM
Is the heater valve open ?
Did you check the head for cracks ?
#17
Posted 26 February 2012 - 08:34 AM
#18
Posted 26 February 2012 - 08:47 AM
Possibly just the heater rad filling up after being empty??
I doubt the heater was drained though? Bit of a faf getting it empty.
OP, did you totally drain the system or did you just pop the bottom rad hose off to remove?
If you just popped the rad off then once refilled you shouldn't add much more than a couple of litres once it has run. If you totally drained the system, heater matrix and all then you can spend ages and litre after litre of coolant getting all the air out.
I have a nagging in the back of head that thinks the block has gone but if it didn't over heat then that's pretty unlikely. A compression test will be VERY useful to do now!
#19
Posted 26 February 2012 - 01:07 PM
I'm not ruling out cracked block/head, but there was no overheating at any point.
Went for a run before, drove it 1/2 mile round the block and it got up to temperature worryingly quick. Opened the rad to check for bubbles etc. It pushed a fair bit of coolant out, then settled at a level with a bit of foam on top and some steam (don't think it was exhaust gas).
Also feels a bit sluggish. Oil is clean though.
Am I just avoiding the inevitable fact that it's blown again?
Edited by minimissionary, 26 February 2012 - 01:08 PM.
#20
Posted 26 February 2012 - 01:26 PM
#21
Posted 26 February 2012 - 04:06 PM
I've now come to the conclusion that something is very wrong. The block must be warped, as it's apparently blown on a coolant feed, rather than a coolant and oil last time. Horrible. Engine out time I suppose. Good old daily drivers
#22
Posted 26 February 2012 - 05:26 PM
The chinese gasket blew all the coolant out of the (open) rad cap as soon as the thermostat opened. Its not sp bad to change them, just a royal pain to get a new one.
Edited by Blatherskite, 26 February 2012 - 05:29 PM.
#23
Posted 26 February 2012 - 05:41 PM
#24
Posted 26 February 2012 - 06:42 PM
Edited by Pauly, 26 February 2012 - 06:42 PM.
#25
Posted 26 February 2012 - 10:06 PM
#26
Posted 26 February 2012 - 10:21 PM
#27
Posted 27 February 2012 - 12:19 AM
#28
Posted 27 February 2012 - 08:47 AM
#29
Posted 27 February 2012 - 11:31 AM
Of course the head was empty, you can't keep coolant in a lifted head it's full of holes. You can't put 4 or 5 litres or litre after litre into a Mini cooling system, or if you can then most of it is coming straight back out somewhere obvious, the system capacity is around 3.5 litres with the heater. The most you would usually need to top up after running having refilled the system is around 3/4 of a litre. Please everyone think more before posting.
Odd way to creep up on the torque values like that, it's not usual for an A series and not needed. Maybe two stages if you must but generally you get them all finger tight, then hit them once to full torque. It might be that it's not sealing because of this. Probably not, but it's unusual so it might be that.
Have you found where the water is going? If you lost 2 litres into the engine in 2 minutes, it would be locked up hydraulically or destroyed by now. I wouldn't do a compression test, I wouldn't turn the engine again now until you have found the water.
Am I right in remembering this is the engine you asked about last week? I have to say that I didn't think hand surfacing the block with emery cloth and then sandpaper was a good idea, but it seemed you had already done it so I left it. It could be that it can't seal because of surface damage, it could be the head is cracked as Roy says but it sounds more and more like there is a physical problem with this engine. It would be very unusual for the block to have failed though.
#30
Posted 27 February 2012 - 07:44 PM
Seems like I should straighten a few things out.
When I first changed the head gasket, the methods used were all wrong (due to poor advice from a family member). Tyre levers were used to prise the head off, and emery cloth was used to clean off the old gasket. The worst damage I can imagine this doing is bruising to the head, and possibly scoring the block slightly. I'd have to be some kind of superman to sand a cast iron block with just a cursory scrub.
The second (and last) time I changed the gasket, I used 260 sand paper with a flat block of wood, gently smoothing things over. The head was professionally skimmed and hot washed, and therefore went back onto the car dry as a bone.
I torqued the head nuts in a gradual fashion, and in the Haynes specified order, because I was being overly cautious about getting the head to settle level. If the head is to be torqued in 2 stages as it says in the Haynes manual, I think doing it in 4 or 5 stages is probably of little or no benefit, but certainly not detrimental to the stability of the gasket seal.
When I refilled the coolant system, I used regular blue coolant with a corrosion inhibitor suitable for cast iron engines. After losing a litre or two of it, I switched to water to save unnecessary wastage. The heater valve was open.
I drove it again today. Went about 1/2 a mile to the garage up the road (long time Mini specialist, has a Mk1 Cooper S among others...apparently) and left it running for the 5 minute conversation I had with him. He mentioned the fact that flushing such an old radiator could have loosened a lot of crap, causing a blockage, especially after having the head hot washed. I then drove the 1/2 mile back without and problems of overheating.
I am going to do a compression test when I get home from Uni, and will also change the radiator.
Conclusion: Agh!
Edited by minimissionary, 27 February 2012 - 07:50 PM.
