Turbo 1963 Build
51 replies to this topic
#31 gorillas1963
gorillas1963
  • Validating
  • 73 posts
  • Local Club: london and surrey
Posted 20 September 2012 - 08:24 AM
Looks good m8! very clean! hope that stops clearance issues and you can crack on with bigger better faster bits
cheers for your comment, i honestly hope thats enough, it makes me think that maybe bulkheads are a slightly different shape on mk1 bodies, if its not enough ive had a suggestion of relocating the actuator by modifying the mount
#32 gorillas1963
gorillas1963
  • Validating
  • 73 posts
Posted 02 October 2012 - 09:54 AM
Here's my comment!
Michael wants to meet up with you sometime to show you his handiwork LOL
ace cafe this thursday if mikes up for it, i can meet you there or meet on route somewhere - maybe get a few together?
#33 Yoda
Yoda
  • 1,958 posts
Posted 02 October 2012 - 03:26 PM
Nice idea, but Mike has the car off road at the moment getting the Turbo head machined and ready for fitting. while it is all off, he will also be facing the manifold mating surfaces to stop exhaust leaks. Hopefully, the next thing will be to rebuild the original turbo block once he has everything else needed to do it. I think, once he has the crank and some new shells, the only other thing needed will be a replacement clutch boss for the one we had to cut in half to get off and a new clutch. I think the flywheel is ok, so the only other things to check are the the bore/rings etc and camshaft and bearings. With a bit of luck, he should have it ready for next seasons shows. but until then, its low boost LOL
#34 gorillas1963
gorillas1963
  • Validating
  • 73 posts
Posted 22 May 2013 - 11:20 AM
roll cage in, gonna go with red carpets because ive got em spare and i think its sets off the black and egg shell
Attached File  IMG_1567.JPG   120.51K   15 downloadsAttached File  IMG_1568.JPG   106.81K   7 downloads
test fitted the seats and im gonna bolt em straight to the floor with plates under the body
Attached File  IMG_1569.JPG   103.93K   13 downloadsAttached File  IMG_1570.JPG   114.14K   11 downloads
Edited by gorillas1963, 22 May 2013 - 11:38 AM.
#35 gorillas1963
gorillas1963
  • Validating
  • 73 posts
Posted 22 May 2013 - 02:46 PM
KAD qudrants fitted
5D22711B-E0B4-4E98-94E5-D17DD59D19BB-313
and blue braided lines
8C79673B-15CE-41C3-BFFF-661F6825FAD6-313
#36 twistedtorment
twistedtorment
  • 60 posts
Posted 22 May 2013 - 11:16 PM
looking good mate! keep this progress up and you might be driving me in it soon!
#37 gorillas1963
gorillas1963
  • Validating
  • 73 posts
Posted 23 May 2013 - 10:28 AM
cheers dude, L2B might be to optomistic but ill be hitting the very next mini event !!
#38 Yoda
Yoda
  • 1,958 posts
Posted 23 May 2013 - 02:58 PM
See you at santa pod then.
Where have you been Buddy. Yoda is in for a bit of bodywork before hitting the road again.
#39 jamesmpi
jamesmpi
  • 1,940 posts
Posted 23 May 2013 - 04:29 PM
Great build. Keep it up! Nearly finished ;)
#40 gorillas1963
gorillas1963
  • Validating
  • 73 posts
Posted 24 May 2013 - 12:09 PM
im literally going to every show when shes done - its been a long time coming !!
Edited by gorillas1963, 24 May 2013 - 12:10 PM.
#41 gorillas1963
gorillas1963
  • Validating
  • 73 posts
Posted 11 February 2014 - 02:04 PM
few little updates in the past month or two including last install of the wrapped manifold and turbo unit and plumbing of the stainless pipes to the twin capacity Renault 5 intercooler - I made the little brackets for the intercooler to bolt to the inner wing and had them welded by alpha welding in Croydon (top bloke if you need him), mocked up the plenum piping and that's been sent to the welder also. the crusty alternator has been changed since though
ive also put all the switches and buttons on the morris minor dash including the fuel pump
back lights and number plate fitting all attached now
4D22DE4C-AB7E-4FC3-AC82-2F9DB0B279E8-190
banded steel are now and I couldn't be happier with them
 goin for wiring this weekend as I make an effort to stay away from wires - too scared of getting it wrong!!
#42 gorillas1963
gorillas1963
  • Validating
  • 73 posts
Posted 11 February 2014 - 02:08 PM
just a bit of advice for anyone who ever takes apart a mk1 - KEEP EVERY SINGLE NUT, BOLT, AND SCREW. it took me a while to locate everything new but when I did this place is the one stop shop for mk1 parts and they are really helpful
http://bullmotifminispares.com/
#43 gorillas1963
gorillas1963
  • Validating
  • 73 posts
Posted 11 February 2014 - 02:10 PM
current state of affairs with the wiring, the plenum is all weded up and painted and ive made a mount for the DSN classic thermostat mount and housing to bolt to - still lots of work to do but watch this space
Edited by gorillas1963, 11 February 2014 - 02:11 PM.
#44 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 11 February 2014 - 07:55 PM
:wub:  Excellent work
#45 LosLandenos
LosLandenos
  • 75 posts
Posted 11 February 2014 - 09:17 PM
Nice build!! Looks evil..
