Mr Flash - 1992 Standard City
153 replies to this topic
#151 BrAd2012
BrAd2012
  • 124 posts
Posted 27 May 2013 - 01:00 AM
Happy to see it back on the road again XD.
#152 rob963
rob963
  • Just Joined
  • 350 posts
Posted 10 July 2013 - 10:39 AM
Well. I have been running the car for a while now (bout a week before london to brighton) and ut has been running just fine.
Only a couple of problems, namely a slight rattle at idle speed, which I think is the drop gears and a slight fueling issue which sort of feels like a misfire but not quite most of the time, just some popping. Might check the needle valve/float and then failing that, possible condensor and points/rotor arm.
However, I have come to the conclusion that he is too expensive for me to keep running at the moment.
So as of monday, I will be cutting around in something much bigger, comfier, more frugal and reliable. But still interesting. A 1.7 td Citroen BX estate.
I will still be doing things to the mini whilst it is in storage, but not necessarily very often. Not that I wanted to stop running it, because I love it, just can't afford it :(
That's all,
Rob
#153 The Otter
The Otter
    The artist formally known as j322overthetop
  • 620 posts
Posted 10 July 2013 - 04:34 PM
To be pedantic here, it's actually a 1.8 if you round the number of ccs  :mrcool: They call it a 17 (not 1.7) because that's the first two numbers of the displacement figure, which is 1769cc  :1eye:
and don't count on it being more reliable just yet  :lol:
#154 rob963
rob963
  • Just Joined
  • 350 posts
Posted 10 July 2013 - 08:53 PM
  >_<  fine. A 1.8 TD. happy? :D
haha engine wise, it *should* (touch wood) be more reliable, once the timing belt and the water pump are done this weekend :shifty:
