The Long Awaited Mini Turbo Dream
#16
Posted 07 April 2012 - 01:51 PM
#17
Posted 08 April 2012 - 12:11 AM
any good advice with bearings? who is a good reliable company.....i dont really want to have to do this again
so phil are you saying i could start with any 1275 head, and just modify it, and open it out a bit?
and another thing, iv heard the 998 gearbox will fit a 1275, only differences being final drive and the diff? how true is this? as im going to be taking it easy to begin with and not really put any power down until iv worn the engine in. so im not worried about blowing the diff, just really if it fits, and if it will handle it being driven sensibly? im thinking weekly oil changes to help prolong it a bit aswell thanks guys
#18
Posted 08 April 2012 - 12:20 AM
#19
Posted 08 April 2012 - 10:38 AM
bearing wise, std ones will be fine as your not going to be reving the engine like a race engine, but you may as well use the competition bearings as they are not much more.
http://www.minispare...id=38347&title=
Head wise I wouldnt look at moding it yourself, the A head is a bit peculular, Phil above is a good head modifier, I'd recomend him, or look for a 2nd hand modded head and get the chambers modded to get a decent compression ratio.
Yeah the box's are interchangable, the diff ratio is ofen the same on the 998 but can be different, however the dropgears will be different on the 998 due to the crank, but they can just be swapped.
Starters are mostly interchangable, check the no of teeth on the ring gear, genrerally the vero is 129 teeth and the preverot 107 teeth and verto's use the pre engaged starter, but there can be exptions where people have swaped stuff...
http://www.minispare...x?ty=ad&aid=305
#20
Posted 08 April 2012 - 01:49 PM
il look into an already modded/turbo head and i can only try the box i suppose, but how much are the 1275 drop gears? wil i be better off just getting a new box?
#21
Posted 08 April 2012 - 03:51 PM
drops crop up on ebay, I'm sure you could pick up some cheaper than this,
http://www.ebay.co.u...=item4d0009eeaf
or ypu could go for a set of straight cut ones.
http://www.ebay.co.u...=item1c1a79aaa3
#22
Posted 08 April 2012 - 07:24 PM
#23
Posted 10 April 2012 - 05:41 PM
#24
Posted 10 April 2012 - 08:31 PM
#25
Posted 25 April 2012 - 01:39 PM
front subframe removed, to weld a plate in behind it, (i found a hole, right where the bulkead meets the floor pan, all welded back together, and a nice thick reinforcing sheet welded in at the subframe rear mounting point)
while out, replaced all the rubber bushes for polly bushes
recieved my metro turbo cylinder head..... (phil can we arrange for you to have it in for chamber enlagement/de-beak please?)
subframe back in and car is finally back down on the floor
iv stripped the gearbox off my 998, condition looks ok, not amazing, but will hopfully do for running the engine in purposes
ih had my crank measured to confirm the 20 thou regrind and bearings are on order, should be here hopefully friday,
#26
Posted 24 June 2012 - 06:26 PM
Make sure you fit big enough fuel pipe. I fitted an electric pump from an old astra and welded a return pipe into my tank. I ran with standard pipe at first and had problems at high revs, turned out i needed a bigger fuel pipe. You Will also need to look at the compression, and i would definately run with super unleaded. I took out my turbo and fitted a vaux engine because i had a standard metro 1275 and when the old 4 star was phased out i had to back off the boost. It was a cheap fix at the time to fit the vaux rather than mod the 1275. This time ill sort the 1275.
Good luck, hope the build goes well.
Edited by jd24-7, 24 June 2012 - 06:27 PM.
#27
Posted 25 June 2012 - 02:22 AM
#28
Posted 11 July 2012 - 12:52 PM
engine is back on the gearbox, flywheel and clutch back on, new turbo oil pump in, uprated water pump on, all new gaskets fitted all round brace bars fitted, painted the back seats and got rid of lots of un necessary wires which were routed under the rear seat cushions, iv cut my curley carbon dash down so the center pod doesnt go to the floor anymore, and with the extra iv cut off, iv made carbon fibre blanking plates for the air vent intakes, next is to send the head off to phil for beak removal and machining to fit dry decking kit, going to take a little trip over to min-its on friday to get new engine/head studs and bolts, pushrods and possibly an ally rad (depending on price) it appears im also missing 2 of the shorter gearbox bolts that fix to engine, so im going to get a complete new set of theses as well.
still a while to go yet, but wont be too long until the engine goes back into the car, iv gone abit ocd with taking pictures throughout the whole build so hopefully the album i put together should be interesting and really show all the changes that have been made to the car along the way
a quick thought, im in need of a megajolt ecu or similar, if anbody is selling or knows of anybody selling 1 could they please get in touch
#29
Posted 13 July 2012 - 04:00 AM
#30
Posted 13 July 2012 - 04:07 PM
