Does Anyone Ever "fake" The Outside Door Hinges?
46 replies to this topic
#31 kezzkitkat
kezzkitkat
  • 714 posts
Posted 22 February 2014 - 06:08 PM
What you going to do with the windows... Leave them rollers.....
Can I ask where you got hinges for,£22 very interested...alloy ones?
Leave the windows standard for the time being as converting to sliding windows so yes roller
And the two a panel was 22 not the hinges
And my hinges were off a mk2
That word alloy = lots of money the only ones I can think of are billet from force racing
#32 kezzkitkat
kezzkitkat
  • 714 posts
Posted 26 February 2014 - 06:37 PM
Just to inform ive done one side have normal glass and winder and works perfect so no problem with Windows catching and so forth
#33 tiger99
tiger99
  • 8,584 posts
Posted 28 February 2014 - 05:56 PM
Instead of all the complexity and ugly mechanism of the hinge shown earlier, if you just want the hinges to look like MK 1 when the door is closed, can't you just remove the pins from a set of MK 1 hinges, file or machine the slot and tongue to get plenty of operating clearance, and screw the two halves to the door and A panel, so that they just disengage when the door is opened?
Actually, MK 1 hinges may have some real value, so you could get a casting kit, with silicone rubber mould material, and cast your own in Mazak, or even epoxy. Once painted, it matters not what they are made from, as they have no structural function.
#34 kezzkitkat
kezzkitkat
  • 714 posts
Posted 02 March 2014 - 06:45 PM
You could do
but 2 question
What's the point in buying a set of hinges to basically destroy them to fit mk3 and bolt them on I would rarther remove the internal hinges and reinforce the a panels and door
And how long would it take to make the hinges?
As it be far quicker to use hinges that look good and actually work
#35 rob#155
rob#155
  • 268 posts
Posted 03 March 2014 - 08:47 PM
The only issue I can see that hasn't been mentioned yet is the external hinges taking the weight of the heavier door.
Because the hinge pins are so short they will be under a lot of stress so the pins will wear quicker leading to the doors dropping.
Edited by rob#155, 03 March 2014 - 08:48 PM.
#36 bpirie1000
bpirie1000
  • Area Managers
  • 2,366 posts
  • Local Club: Amoc
Posted 03 March 2014 - 09:45 PM
Good point... I am thinking roller poly windows.need to get the scales out..
Anyone done the measurements on a mk1boot is it the same as a mk3??
#37 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,033 posts
Posted 03 March 2014 - 10:13 PM
the mk1 and mk3 boots are the same size, just have a different outer skin.
#38 clubman0_1
clubman0_1
  • 12 posts
Posted 27 July 2014 - 11:32 AM
So may he reviving an old post or asking a question again. Who is the Japanese company that does external hinges as arc angels no longer do theirs. Also is there any way to get them in the uk simply or does anyone know of an unused set for sale
#39 kezzkitkat
kezzkitkat
  • 714 posts
Posted 27 July 2014 - 07:11 PM
The word thats spring to mind is 'expensive' I personally spend the money else where
Plus I canr see anybody selling them if they have them rarther do the job properly or not at all sorry to be so negative
#40 clubman0_1
clubman0_1
  • 12 posts
Posted 27 July 2014 - 10:55 PM
Cost is not an issue. Fitting mk1 inner a panels when it's a new shell is. Steel doors on car with winder mechanisms already and glass so no quick easy way around it. It's more about aesthetics. Just can't remember name of Japanese company and arc angels have stopped making them. Looked at a diy option using an origional hinge but geometry is all wrong
Edited by clubman0_1, 27 July 2014 - 10:55 PM.
#41 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 28 July 2014 - 12:32 AM
These?? http://www.chubu-ori...e=detail&id=139
#42 kezzkitkat
kezzkitkat
  • 714 posts
Posted 28 July 2014 - 06:50 AM
Dont need mk 1 inner a panel just reinforced the a panels with two triangles and weld them on then bolt the hinges through it im ones of these people that have done it and it works not had any door drop etc the fake ones do look good when shut but look dreadful when open and there's a few people who tryed making but bave failed
#43 69k1100
69k1100
  • 376 posts
Posted 28 July 2014 - 01:51 PM
Australian minis have windup windows and external hinges . However if you have doors with side intrusion bars that will add to the weight significantly. The trick is to keep an eye on the bushes, of you wear through them the hinges are junk pretty quickly.
The inner a panel stiffener isn't that expensive anyway, but the magnum ones need a lot of cutting/hammering and welding to fit right.
#44 clubman0_1
clubman0_1
  • 12 posts
Posted 29 July 2014 - 02:04 PM
 thats the ones. ahs anyone in the uk fitted them or got a set ?
#45 AVV IT
AVV IT
  • 6,122 posts
  • Name: Dave
Posted 29 July 2014 - 06:29 PM
I'm sure someone was trying to do a group buy/import of them here a while back, not sure if it ever happened though. I'll see if I can find the original thread.
