On your amp, your bass is a Low Pass Filter, it allows only frequencies lower than a given point to pass through. Basically anything below the dial.
The other two are High Pass and they allow only frequencies above a given point to pass through.Basically anything above the dial.
For your sub, set it no higher than 120Hz,then adjust down to your liking, the higher you go the more sloppy it will sound because your going more to a full range instead of bass. For a Clean bass I find around 80-100Hz works well.
For your front, I assume the external crossover is being used for the tweeters. If your also using it for the Speaker you can set the Frequency level to 120, this gives you a back up bass blocker just incase the external acts up. Either way start there and increase the filter level up until distotrion is eliminated. Reapeat this for the rear as well.
Do this at about 3/4 volume, find a good tune that fits what your music type is or find a driver test to tune in each component.
MTX makes a good one or try IASCA.
Here's My own Guidline for Component Crossovers, Hope it helps.
Bass 0Hz -100Hz
Mid Bass 100Hz - 250Hz
Mid Range 250Hz - 3000Hz
Hi Range 3000Hz and up
This should get you in the right direction.
by the way I see your sub box looks like it has a few spots where they don't seem to join flush. Did you seal the inside? Air leaks will effect the function of the subwoofer. If you didnt's use a window or rubberized calking on the inside on the seams.
Edited by TA2DMAC, 13 May 2012 - 03:44 PM.
