Instructables, courtesy of Ruckus::
http://www.theminifo...showtopic=93783
Posted 14 May 2012 - 08:49 AM
Posted 14 May 2012 - 09:05 AM
Posted 14 May 2012 - 09:10 AM
Posted 14 May 2012 - 12:11 PM
Test fitting is important to make sure the sub is high enough (mine really could do with being 15m higher) to clear the wheel arch, being too close can make for a ballache getting it in and out.
Posted 14 May 2012 - 12:18 PM
Posted 14 May 2012 - 12:27 PM
"a fairly reasonably priced sub?"
It's all relative, to some 'reasonably priced' is 15 grand to others is a tenner... Without a ball park figure it's hard to recomend.
Also are you saying that you head unit only has a single RCA preout and that is for subwoofer only, and other than that it's just speaker level outputs?
It's got a single RCA, and it's labelled sub-woofer, but I think it's full range as it worked OK hooked up to the channel with the comps on.
I'm thinking ~£150 or so, but I'm well aware you get what you pay for.
Thanks for the help
Posted 14 May 2012 - 04:58 PM
Thanks for the help
Did you confirm that the RCA does have a full range output?
OH and some amazing subs all under your budget.
http://www.talkaudio...044-dual-4-ohm/
http://www.talkaudio...0-dual-4ohm-vc/
http://www.talkaudio...energy-hx250d4/
http://www.talkaudio...5cuft-box-32hz/
All are dual 4ohm Voice coils so you can Wire them in Parallel like this.
And your amp should give you 400 watts rms!
Might be worth running a higher rated fuse with this setup..
Or a bit less SPL and more SQ.
http://www.talkaudio...2501-subwoofer/
Posted 14 May 2012 - 05:05 PM
Posted 14 May 2012 - 05:08 PM
I've not had any problems with the strength of seal on my set up (still running the sub in, mind you), I did worry at first I'd open the boot and find it laying in the middle, having popped out.
Currently it stays in place by virtue of super tight fit, should it start shifting once the sub is run in then I'll pop a couple of screws in the sides but there's no perceivable air loss currently.
Of course if you're building for competition standard then it's a different story, I'd imagine.
Posted 14 May 2012 - 05:11 PM
Posted 14 May 2012 - 05:15 PM
Posted 14 May 2012 - 05:22 PM
Posted 14 May 2012 - 07:08 PM
Posted 14 May 2012 - 07:10 PM
Posted 15 May 2012 - 08:31 AM
One sub box carpeted
I'm thinking with the boot lid to deaden, stuff with fibreglass and stick a sheet of carpeted fibreboard over the top.
