How many Turbos ?
Turbo Phil
, May 21 2004 07:54 AM
47 replies to this topic
#16
Posted 23 May 2004 - 04:45 PM
ill have one one day
#17
Posted 23 May 2004 - 09:37 PM
Theres a 1405cc turbo for sale in the Mini Mag, for all you lookers out there!
#18
Posted 24 May 2004 - 10:30 AM
I've got one
they are great :grin:
1310 Hybrid turbo
Nice loud dump valve is a must
Ideal for scaring the cofin dodgers :cheese:
1310 Hybrid turbo
#19
Posted 24 May 2004 - 04:24 PM
Are they reliable?
#20
Posted 24 May 2004 - 09:58 PM
#21
Posted 25 May 2004 - 07:39 AM
>Are they reliable?
Yep
I've had mine for 2 years now only broken down once.
split water pipe
silicons worthwhile because of turbo temps, or a least new rubber hoses
been off the road recenty for a new head and a bit of a tidy up after it starting to smoke a lot.
old head was knackered. was still the original head mind you.
They need looking after but doesn't any tuned ASeries.
Just have to be careful, too much boost and not set up properly and she'll pop!!!
Yep
split water pipe
#22
Posted 01 June 2004 - 11:01 AM
I've got one, it's a 998 as some of you might know.
Wil
Wil
#23
Posted 01 June 2004 - 11:36 AM
I'm in the process of building one but using a specially sealed weber instead of the SU.
#24
Posted 01 June 2004 - 09:04 PM
The lotus esprit turbo carb may be suitable (delorto i think )as they are a blow through carb .
#25
Posted 01 June 2004 - 09:35 PM
Yes the Dellorto 40 from the Lotus Esprit is suitable Janspeed used them a long time ago on their Turbo A-Series engines.
Here's mine .....
Phil.
Here's mine .....
Phil.
Posted 01 June 2004 - 10:51 PM
In effect, the Dellorto and the Weber are the same, kind of.
Phil are you on here quite often only seeing as you rhave already done this I could use your expertise?
#27
Posted 03 October 2008 - 02:45 AM
Here is one from DK IMM 2007, car is now MOTed and running again after 9 years of sleep(8 in my owner ship)
Posted 03 October 2008 - 07:28 AM
Nearly as long sleep as this topic's had lol
#29
Posted 03 October 2008 - 02:20 PM
To replace my super high comp 1293:
gt28rs
custom manifolds ect.
1380cc
avonbar pistons
k100head
Lobeless cam
miglia spec crank
lightened, balanced and polished a+ rods
high flow oil pump
electric water pump
4 bolt centre strapped, s/c box (s ratio)
s/c drops, 4 pin diff
8.5 compression ratio
padel clutch
and all the rest of that malarky.
gt28rs
1380cc
avonbar pistons
k100head
Lobeless cam
miglia spec crank
high flow oil pump
electric water pump
padel clutch
#30
Posted 03 October 2008 - 03:03 PM
im planning on building a turbo engine over the winter, brought a metro turbo engine of ebay for £75, didnt include the head or ancillaries but its a good place to start from.
And turbo phil, i may well be contacting you for some cylinder head work in a few months my mate Ian W said you were the person to get hold off.
Edited by dan_up850, 03 October 2008 - 03:04 PM.
