Battery Issolator Switch
21 replies to this topic
#16 freshairmini
freshairmini
  • 1,718 posts
Posted 29 June 2012 - 11:35 PM
the multimeter needs to be set to it shows of a figure to one decimal point (eg, 00.0v). when charging you need about 13-14volts (at idle). off should be 12volts.
Cleaning up the fuse holders on mine gave it a bit more life. great when moneys tight! :-)
#17 jmmini
jmmini
  • 711 posts
Posted 29 June 2012 - 11:44 PM
I'm supposed to be taking her to be looked at for several parts I've got and not fitted, the main is a center exit exhaust but also I have a push start button type thing, with my dodgy wiring would it be better to leave this for now?
I have another car (for when the moody mini won't start) with a 12v battery, should I change this over and see if this battery also drains?
#18 freshairmini
freshairmini
  • 1,718 posts
Posted 29 June 2012 - 11:59 PM
be easier to diagnose with the multimeter, no need to remove an move batteries...
#19 jmmini
jmmini
  • 711 posts
Posted 30 June 2012 - 12:11 AM
Just found out a little battery tester in kitchen drawer, the type that light up. I'll slap this on it in the morning and have a look then
#20 jamesmpi
jamesmpi
  • 1,940 posts
Posted 30 June 2012 - 07:31 AM
Don't think that light up battery tester will be much use. All that'll do is light up if there is a voltage. You need to know the amount of voltage present which only a multi meter can tell you.
#21 freshairmini
freshairmini
  • 1,718 posts
Posted 30 June 2012 - 10:06 AM
Plus you might bugger the battery tester with all that current!
Edited by freshairmini, 30 June 2012 - 10:06 AM.
#22 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 30 June 2012 - 11:56 AM
Not exactly. Battery testers (like voltmeters) allow/draw minimal current. However, most testers for dry-cell batteries are designed for 1.5V cells. (Some may also measure 9V batteries as well). Hooking such a tester to a car battery won't damage it by current but the over-voltage certainly can let the white smoke out of the components.
