Subframe - Jacking Points And Other Matters
39 replies to this topic
#16 maccers
maccers
  • 1,876 posts
  • Local Club: LSMOC
Posted 08 August 2012 - 11:48 AM
Re the holes, probably a battry cable clamp or something, mine fell off ages ago!
#17 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 08 August 2012 - 11:50 AM
Ok I'll try not to worry about it. Just get worried with this car as the more I look and investigate under it the more I find wrong!!! I'm near Winchester, used to live in Ashtead funnily enough, but not that near now. I'll see how I get on! :-)
#18 maccers
maccers
  • 1,876 posts
  • Local Club: LSMOC
Posted 08 August 2012 - 12:06 PM
Ha me too! Used to live down by the Railway Line on Woodfield. If its starts to slip or creak, let it back down and try it again, dont rush it.
#19 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,096 posts
  • Name: Neil
Posted 08 August 2012 - 01:06 PM
If you want to get a low level entry light weight trolley jack with a built in rubber pad then i can recommend this one from Machine Mart. Its not cheap but if you buy it on a VAT free night then its 20% off.
http://www.machinema...=1&TC=SRC-jacks
We use this on Project Erm and its very good.
#20 maccers
maccers
  • 1,876 posts
  • Local Club: LSMOC
Posted 08 August 2012 - 01:13 PM
Thats the precise jack I have. Also have Halfords one too but the seat is much taller when its at full rest. The MMart one is great!
#21 tiger99
tiger99
  • 8,584 posts
The offside subframe lower flange should have a round-headed screw which retains the battery cable clamp, but there is no wiring on the nearside, so the screw on one side only is correct. All of my Minis were like that. The screw itself is a right pain, like all roundhead screws, and is often replaced by a hex head bolt or whatever comes to hand.
You may well ask why Rover wasted money drilling a hole that was never used. I think it may be used on some models for foreign markets, where legislation required differences in the electrical system etc, but likely they put it in initially in case it was needed. Cheaper to allow for options in the tooling up front than to modify it later.
#22 tiger99
tiger99
  • 8,584 posts
Posted 08 August 2012 - 01:18 PM
As for jacking, when I have been raising the shell to drop a front subframe, I have used a length of 4*2 across the front of the floor, right at the junction with the toeboard, and a central trolley jack. Obviously the exhaust would be in the way so you need to remove it first. I have never bent a floor that way, and the structure there is stiff in every direction. It allows you to go high enough to get axle stands under the subframe side members. The strongest point is on the double thickness below the lower suspension arm, and blocks of wood help avoid doing minor damage to the subframe.
#23 TA2DMAC
TA2DMAC
  • 755 posts
  • Local Club: Michigan MINI Motorin Club
Posted 08 August 2012 - 01:27 PM
Instead of using two jacks set a pair of 2x6'sused on the ground in front of the tires and drive up on them.
It will give you the little bit of height you need to get the jack under.
I have to do that to get a jack under my motorcycle because it has been lowered 4 inches.
#24 lewBlew
lewBlew
  • 1,238 posts
Posted 08 August 2012 - 01:28 PM
Ah that jack is a bit out of my price range. Was thinking more one of these!
http://www.machinema...lley-jack-ctj2b
http://www.halfords....tegoryId_255207
#25 Noah
Noah
  • 4,136 posts
  • Local Club: Essex Mini Club
Posted 08 August 2012 - 01:45 PM
Apparently the bog standard Halfords trolley jack fits under either subframe... I'm planning on getting either that or one from Machine Mart which is similar but £10 cheaper. In any case, can you jack it up on the flat bit of the subframe and then put axle stands right next to where you jack it up - is the area big and strong enough?
Get a low profile jack.
#26 maccers
maccers
  • 1,876 posts
  • Local Club: LSMOC
The smaller yellow one does not raise that much, I have this one and never use it. I then bought the halfords advanced one, that has a much higher lift on it. Then I bought the MMart one, that is mid way between the two in terms of height.
#27 lewBlew
lewBlew
  • 1,238 posts
Posted 08 August 2012 - 01:53 PM
Like this?
http://www.machinema...ofile-trolley-j
It is low profile and goes to 33cm. The cheap MM one says only 208mm and the Halfords one 38cm..
#28 maccers
maccers
  • 1,876 posts
  • Local Club: LSMOC
Posted 08 August 2012 - 02:17 PM
This is the other one I have that goes very high, probably too high!
#29 sonikk4
sonikk4
  • 16,096 posts
  • Name: Neil
Posted 08 August 2012 - 02:31 PM
Got that one and its too big to carry around in a car. Does the job but its not the handiest bit of kit to carry around.
#30 maccers
maccers
  • 1,876 posts
  • Local Club: LSMOC
Posted 08 August 2012 - 03:03 PM
Yep, its a bit clunky for sure! I only carry a small scissor jack and wheel brace in car - and my AA card!!
