i use the sump with a piece of wood to protect the fins to jack up the car and then put axel stands covered with rag under the side members or front corners of the subby...just don't ever use the sills![]()
Do NOT lift the car like this. You are effectively suspending the car weight on the RUBBER engine mounts. Jacking point should be under the flat part of the subframe each side.
it's not the best way to jack the car up but i don't want to scratch my subframe
