Here is this proof/inspiration of the 13" steels banded to 7" wide...
This is for sale on ebay at the moment isn't it?
Posted 08 August 2012 - 03:31 PM
Posted 08 August 2012 - 03:48 PM
Posted 08 August 2012 - 03:53 PM
Posted 08 August 2012 - 04:49 PM
Edited by craig 1010cc, 08 August 2012 - 04:51 PM.
Posted 08 August 2012 - 07:58 PM
Posted 08 August 2012 - 08:39 PM
Posted 08 August 2012 - 09:11 PM
Is a 13 inch steel wheel not very heavy for a mini ? The red mini must had some serious trimming at the arches to make it fit like that no ?
Posted 08 August 2012 - 09:20 PM
Mine aren't banded they are new outer hoops with centers tig welded in. As in my other thread, that's how they were made up. Been running them for months now, they aren't all that heavy, and ontop of that I went with a taller tire to give me a little more sidewall for comfort on 13's. Worked out good, still need to find the time to look for some center caps just to fit hole in the middle to finish it off. I ended up not liking the chrome caps to cover the center.
Posted 08 August 2012 - 09:27 PM
Good info! After hours of researching and stressing i think i will just be getting 12" mini steels, banded out to 7" (s) wideBanded steels, are they legal, yes (legally no different to welding your heelboard, need to be fit for purpose).
Can you run 4x100 PCD wheels on a mini, yes, BUT you will put stress on the wheel studs and risk them failing. You can get around this by using wobble nuts, but not a route i'd want to go (plenty of VW's use wobble bolts to run Mini alloys though)
The wheels in question I think are off of a Vauxhall victor fb. Other sources of 4x4" 13" OEM steels are Vauxhall Viva (but not Chevette, thats 4x100), MG midgets amongst others
Were to get them banded. Few options, on ebay there are a few places offering it, www.bandedsteels.com or go on to retro rides and hunt out either JamseP or Dez. I used JamesP to build me a set for my MX5 a few years back, and Dez is an amazingly skilled fabricator
edit: those wheels are based on mk1 golf steels, so will be 4x100.
Posted 08 August 2012 - 09:37 PM
Posted 08 August 2012 - 10:41 PM
Posted 09 August 2012 - 08:58 AM
you do know you can't get a 175/185 road tyre in 12 inch don't you ?
Posted 09 August 2012 - 09:42 PM
Posted 22 August 2012 - 03:09 AM
Posted 22 August 2012 - 06:37 AM
