Chloe '99 Cooper - 1380Cc
101 replies to this topic
#91 o0OWILKSO0o
o0OWILKSO0o
  • 405 posts
Posted 13 August 2025 - 06:05 PM
This one is the problem child though…
Can’t seem to find a replacement connector for the large one.
Edited by o0OWILKSO0o, 13 August 2025 - 08:30 PM.
#92 johnR
johnR
  • 2,322 posts
Posted 14 August 2025 - 08:50 AM
Tried Autosparks?
#93 o0OWILKSO0o
o0OWILKSO0o
  • 405 posts
Posted 14 August 2025 - 07:06 PM
Tried Autosparks?
I will have a look, I have managed to re-pin it, so may not need to connector.
#94 Avtovaz
Avtovaz
  • 1,315 posts
Posted 14 August 2025 - 08:27 PM
you dont need a connector, you need the pins, and a depining tool.  You can get them from ali express or probably over here too. When i had the R100, i repined a few connectors when i did the speeduino. Where it is bare on one of the wires, looks like someone has been fault finding.
Edited by Avtovaz, 14 August 2025 - 08:28 PM.
#95 o0OWILKSO0o
o0OWILKSO0o
  • 405 posts
Posted 14 August 2025 - 08:30 PM
That’s what i have done today. Had a delivery of Econoseal pins both male and female. And the actual Econoseal crimp cool.
Has made a huge difference being able to untangle everything.
All back together after a few days of work.
#96 o0OWILKSO0o
o0OWILKSO0o
  • 405 posts
Posted 14 August 2025 - 08:33 PM
Replaced clutch slave cylinder and mounting bolts.
Switched to a one piece hose.
Then bleed the system. AND……. she started and drove.
#97 o0OWILKSO0o
o0OWILKSO0o
  • 405 posts
Posted 14 August 2025 - 08:35 PM
Isolated radiator fan harness…
Turns out fan had taken on water and seized, so that’s my next purchase.
#98 o0OWILKSO0o
o0OWILKSO0o
  • 405 posts
Posted 14 August 2025 - 08:36 PM
Isolated spot light wiring harness and removed the two spots…
#99 o0OWILKSO0o
o0OWILKSO0o
  • 405 posts
Posted 14 August 2025 - 08:38 PM
Separated loom, ere moved obsolete MPi ECU feeds…
Relocated engine bay fuse box to behind brake servo.
Re-routed all wired and temporary made engine bay harness.
#100 o0OWILKSO0o
o0OWILKSO0o
  • 405 posts
Posted 14 August 2025 - 08:40 PM
Weekend job will be to finish off the last bit of loom and re-pin the Econoseal connectors…
#101 o0OWILKSO0o
o0OWILKSO0o
  • 405 posts
Posted 14 August 2025 - 08:43 PM
Toys arrived from PoleVolt and Amazon…
Econoseal crimp tool
New connectors
Pins and grommets
De-pinning tools
Then set to work sorting some connections out…
And a bit of heat shrink to replace sticky electrical tape…
#102 o0OWILKSO0o
o0OWILKSO0o
  • 405 posts
Posted 15 August 2025 - 10:07 PM
The youngest cleaned her today.
Night shoot hides MANY imperfections!
    Bing (1)
