I'm sure I've read that the holes were drilled in line with the subframe, and that they aren't interchangeable. I could well be wrong.
Are the solid neg. camber brackets that bad?
Radius Arm & Camber Bracket - Is This Gap Normal?
colinu
, Aug 16 2012 06:59 AM
18 replies to this topic
#16
Posted 18 August 2012 - 11:07 AM
#17
Posted 18 August 2012 - 08:08 PM
i filed mine upwards about 3/8 of an inch put them back on and given me around 0 deg to .25 camber
with toe on rear mines standard and its fine for fast road use
differnt if racing you will need about 1/16 toein
#18
Posted 19 August 2012 - 08:31 AM
You need approximately that amount of toe-in always, not just for racing. On the road, any toe-out is potentially lethal as it completely ruins the stability of the car.
#19
Posted 21 August 2012 - 10:12 AM
From my personal experience, I have only seen these style of brackets break under hard motorsport type of use, and even then its been pretty rare...
Yes there are different quality items and the more expensive ones do fit and are of a far better quality (and havent (yet) seen one break)....
I have had my own rallycrosser hit in the side, the arm bent but the bracket stayed in one piece...
All in all, if fitting these brackets I would favour the KAD ones rather than the 'cheap' ones....
