Posted 05 March 2013 - 06:24 PM
I haven't had any real experience of turbos - looked in to it previoulsy but was put off by the expense and the constant need to "experiment" to get the most out of it.
But it is a very subjective issue - particularly cost. After 30 years of playing with minis, £3k doesnt sound that expensive for reliable hp to me. But I wouldnt want to pay for it - the extra few horses that gives over a £1.5k rebuilt/tune doesnt make sense for my uses.
I dont wish to dismiss anyones comments on here, but how you can build a reliable turbo motor on a budget that I would call cheap is beyond me. I accept that you can get some bargain parts - but they tend to be few and far between and take a long time to collect. If you dont know what you are doing, you will just end up with worthless, unreliable junk - most of it is so old and knackered by now that it will need a (professional ?) rebuild.
Unless you can do everything yourself, getting more power is an expensive job. Even the bulkhead mods required for the normal turbo is expensive if you cannot do it yourself. When you add up the cost of all of the anxilliaries (radiators, diffs, carb, dizzy/ignition, manifolds, brakes etc) it becomes quite frightening when originally you only expected to pay a few quid.
Admittedly, my n/a engine came to many thousands to get a decent amount of reliable hp. When you are looking at more than 110 (ish) hp in a reliable/usuable format turbo/supercharging seems to have advantages.
Now (and if I could persude my Mrs), I would probably experiment with turbos as my minis are just play things - in my younger days they needed to be a lot more reliable.
But unless you have that luxury (and it isnt a track car), my own experience says follow the following list:
1. Get a 1275 motor - even as standard you feel a big improvement over a 998
2. Rebuild it so that it is solid and reliable
3. Proper rolling road tune
4. Overhaul the handling
5. If that isnt enough, add a quality head, cam and bigger carbs.
6. Peg any aspirations at 90 hp (ish) to ensure that it is useable - even that will start to expose/wear the diff, gearbox, cooling, etc
Bar horsepower is only any good when you are at the bar. If you are constantly rebuilding/feltling what is the point - Minis are only any good when you are driving them.
