Hello From A Complete Mini Novice.
#16
Posted 05 August 2015 - 09:14 AM
Replaced the gun on my pot bellied sand blaster . Hopefully have the sub frames off this coming sunday. Thanks for looking. Ade
#17
Posted 05 August 2015 - 04:52 PM
You'd be better with plus gas rather than WD40 mate.
A bit of heat often helps too.
#18
Posted 05 August 2015 - 06:32 PM
thanks bud ,You'd be better with plus gas rather than WD40 mate.
for 26 years before i changed career ,i was a refrigeration engineer , ive used quite a few release agents over the years and ive always favoured wd40 , an old engineering trick was to soak in wd40 , the use a little heat to expand the item then quench in wd40 so the expanded item drawed the fluid in capilary style. Never let me down yet , ive had 3 foot scaff poles hanging off 36 inch stilsons to release some very big bolts in the past , used the heat and wd40 trick and theyve released nicely. its a very similar process to quenching in oil to lubricate threads
I should really give an introduction to my history ,43 years ago born into a custom car hot rod custom van family , taught to monkey wrench from a very early age , taught to mig weld at 12 yr old , city and guilds in engineering and vehicle mechs , city and guilds in refrigeration and a/c . Can mig , tig and gas weld , engine , gearbox rebuilds no problem , use a lathe , vertical and horizontal milling machine , panel fabrication . Vehicle and industrial, domestic, commercial electrics savvy.
Found out by chance 10 years ago that i had a knack for upholstery and stitching.
I will try to find the two build threads on retro rides of my 71 bedford cf with 5 ltr v8 and my 72 vauxhall victor fd. Still got to finish the bedford , sold the fd.
Cheers ade
#19
Posted 09 August 2015 - 06:43 PM
had a good day on the mini with my son josh , removed front sub-frame with engine still attached , only damage was we managed to smash the starter motor solenoid when the engine fall over on to the jack resized.jpg 79.68K 3 downloads
then once the engine and sub-frame was safely stored under the shelving , we removed the rear sub-frame , this came out very easy , i'm new to minis but this looked relatively new to me , very clean and no corrosion IMG_1540.JPG 58.62K 2 downloads
once these were off the car , we flipped the shell on its side to have our first proper good look at the underside , turns out the car has its original floor which is mostly unrepaired , there's a couple of small areas that have been patched , the outer sills are original too. IMG_1552.JPG 77.03K 6 downloads
IMG_1559.JPG 65.73K 2 downloads
IMG_1569.JPG 66.42K 3 downloads
IMG_1526.JPG 64.28K 4 downloads
quite pleased with the overall condition of the shell . now the car is starting to make progress the wife is starting to get into it , she's now chosen alloys rather than steels and wants the car in baby blue with old English white roof.
more pics as I resize them and upload them.
cheers ade
#20
Posted 10 August 2015 - 05:52 PM
Hi,
Like the sound of the heat then quench in wd40, have quenched in water before after heating to release nuts but wasn't sure on how wd40 would react so good to hear it works well! On the power steering front, i believe a popular option is a corsa (C i think) unit as the power steering is in the column so just needs a way of connecting to the original shaft. Kit cars are the main users of this unit but i work with someone with a porsche 924 who has done it to that.
Hope all goes well!
Paul
#21
Posted 10 August 2015 - 09:55 PM
Yeah ive been looking at the corsa c column , pretty cheap on ebay to buy.
#22
Posted 10 August 2015 - 11:23 PM
Got the T3 done yet?
Lots of captive nuts on Minis. Plus gas has always been my release agent of choice. No heat needed. But have also used the heat and oil quench.
Liking some of these chill and lube products that are out there now.
Box cushions still doing the job perfectly. Saw quite a few examples of your work at Eastnor castle at the weekend.
Good luck with the Mini.
Nick.
#23
Posted 11 August 2015 - 08:57 AM
Ade you get everywhere.
Nick.
hi nick , lol , majority of the bolts have come out easily , praise the gods . No , my t3 has had to take a back step whilst her who must be obeyed has her mini restored . Nice to know about eastnor , dont manage to get to any shows , all my times up here working. Its a hard life lol.
cheers ade
#24
Posted 19 August 2015 - 02:48 PM
New toys arrived today , bizweld grinding welding overalls , cleco pin and intergrips package , 23 foot scaf pole from a mate too.
Role on sunday , start work on it again.
IMAG1517.jpg 59.1K 4 downloads
IMAG1514.jpg 16.4K 1 downloads
Does anybody know where i can get the shell media blasted. Cheers ade
#25
Posted 19 August 2015 - 08:39 PM
I'm a complete novice too looking to take the plunge and start a project. My first car was a Mini and want to get back into the scene.
I've seen an auto and like you would put an manual engine into it, so how's it been for you so far and has it caused you any headaches????
Looking for all the advice I can get
Andrew
#26
Posted 19 August 2015 - 09:08 PM
#27
Posted 23 August 2015 - 04:30 PM
IMAG1529.jpg 40.61K 1 downloads IMAG1530.jpg 50.12K 3 downloads
IMAG1531.jpg 35.55K 1 downloads IMAG1532.jpg 45.79K 2 downloads
IMAG1524.jpg 57.62K 2 downloads IMAG1528.jpg 52.65K 3 downloads
IMAG1525.jpg 29.66K 2 downloads IMAG1526.jpg 31.2K 2 downloads
Removed the front wings. Going to replace wings , inner wings, scuttle, inner flitch panels , thinking I may fit a new front panel whilst I am at it.
Cheers for looking
Ade
Edited by mid england retrims, 23 August 2015 - 09:53 PM.
#28
Posted 30 August 2015 - 06:40 PM
my son josh has been busy today , I've been re- trimming a Harley Davidson seat. using flap discs with 120 grit da pads and a da sander , he's managed to strip a fair bit of the paint off.
IMAG1567.jpg 72.99K 6 downloads
IMAG1587.jpg 57.04K 3 downloads
IMAG1581.jpg 54.02K 3 downloads
IMAG1583.jpg 62.95K 0 downloads
IMAG1574.jpg 52.48K 4 downloads
IMAG1587.jpg 57.04K 4 downloads
last picture is quite interesting , we found that the rear c pillar has been cut through , welded and fillered in the factory , the filler is onto the metal , then the factory primers over the top.
josh is working on the rest of the car tomorrow as its bank holiday Monday and he's off work. hopefully next weekend we can start sand blasting all the rusty areas.
im on the look out for inner wings . so far it looks like it needs the following ,
inner wings , drivers a post , small repairs to inner sills , outer sills , windscreen scuttle , dashboard top , front floor pans , rear valance , lower boot opening panels , rear quarter bottoms .
IMAG1579.jpg 50.64K 2 downloads
#29
Posted 31 August 2015 - 09:13 PM
more work done today by my son josh. for all the people viewing this thread , please don't think this is a no expense spared company rebuild , we are on a budget with this car but I want to do it right as its my wife who will be driving it daily.
first picture is of my son josh hard at work , he will hate me for this , lol
IMAG1590.jpg 110.7K 5 downloads
IMAG1596.jpg 47.59K 1 downloads
IMAG1597.jpg 37.57K 2 downloads
IMAG1598.jpg 54.55K 1 downloads
IMAG1599.jpg 53.95K 1 downloads
IMAG1600.jpg 58.54K 1 downloads
IMAG1601.jpg 44.23K 1 downloads
IMAG1602.jpg 35.54K 0 downloads
IMAG1603.jpg 44.91K 4 downloads
IMAG1604.jpg 56.02K 0 downloads
IMAG1605.jpg 46.12K 1 downloads
IMAG1606.jpg 45.4K 2 downloads
IMAG1607.jpg 26.17K 1 downloads
IMAG1608.jpg 39.07K 1 downloads
IMAG1609.jpg 48.34K 1 downloads
not original sills as first thought ,
