The main reason i want it is to control the advance better for my s/c (at high and low revs - stop stalling at low and possible detonation at high) aldon custom curve doesn't quite hit the button.
Well, if the chain is good enough to open and shut my valves in a timely manner then thats good enough for me. In reality, I wouldn't be supprised if you could never tell the difference between megajolt and amethyst.
Because it relies on a cam driven by a timing chain so you get chain stretch and you get wear on the dizzy drive gears
I doubt that unless your car is used for racing, sprints or hill-climbs you would notice the difference between Megajolt and points ignition. The advantage for most owners with any sort of electronic ignition is that the points don't need adjusting every few miles.
If a points-equipped 1293 'S' with an Aldon custom-curved distributor costing £100 will do, say, 0 - 60 in 7.4 seconds, how much quicker would it be with a) Amethyst and b) Megajolt? Does anyone know or care to guess?
Aldon Amethyst Mapped Ignition
#16
Posted 04 September 2012 - 04:23 PM
#17
Posted 04 September 2012 - 04:25 PM
Except the Megajolt can be used on just about any type of engine.........
I'll be sticking with one of those A series engines
#18
Posted 04 September 2012 - 04:31 PM
I had to re-build a 1293 Turbo engine which had done 4 miles from new-build (not my me!) before it blew up. The guy had paid cash - no questions - so the builder didn't want to know. It had a standard 1275 Mini distributor and a static C.R. of 15:1. It blew up!
When I re-built it I made the owner get the turbo set with a certificate of boost and Aldon did a special distributor which had the correct curve and it worked fine. No detonation and on the rolling road it performed very well. I guess an Amethyst system would have been ideal had it been available then.
#19
Posted 04 September 2012 - 06:01 PM
15:1 ? bloody hell !
#20
Posted 04 September 2012 - 07:46 PM
To keep it balanced remember mj does more that just your timing... As it has inputs and outputs
#21
Posted 04 September 2012 - 08:41 PM
#22
Posted 04 September 2012 - 09:29 PM
#23
Posted 04 September 2012 - 10:51 PM
#24
Posted 09 September 2012 - 06:51 PM
#25
Posted 09 September 2012 - 08:54 PM
#26
Posted 10 September 2012 - 06:54 AM
#27
Posted 10 September 2012 - 05:05 PM
Edit: Forget that :)
Edited by DannyTip, 10 September 2012 - 05:09 PM.
#28
Posted 10 September 2012 - 06:30 PM
Thus a fixed advance at all rpm, then introducing an actuator that could advance/ retard the ignition by turning the backplate/ rotor arm relative to the shaft.
Or having the rotor completely separate from the shaft, and having a motor or something that could rotate the rotor arm correctly to provide the proper advance.
Or you could have no rotor arm at all, just a sensor that detects the position of the shaft, and an electronic module/relay that fires a spark to the correct HT at the right time.
The more you think about it the more interesting it becomes, trying to work out a reliable way of achieving it...
And to answer Danny's question directly, you would have to adjust the position of the rotor with regards to the shaft, but as they are both spinning quite fast this could be a problem, and I cant really see them using this way as it is too much hassle compared to the other ways of achieving the same thing, as you would need something that would be mounted on the shaft, that could rotate with it, while receiving information about what the advance should be.
#29
Posted 19 September 2012 - 04:01 PM
but megajolt offer better advantages...
Try again...
#30
Posted 28 September 2012 - 10:41 AM
