Hello updates after this weekend im afraid but i was wondering what shall i use for rust proofing? Hamerite?
hi Webby.
there are loads of products out there. some people swear by Hammerite... some hate it... I have used it for bits of the suspension etc but for the undwrsude of the car I am using Clostermans chassis paint. I'm not saying its the best but in my opinion its good. I've used it before for various bits and it seems really good and sets rock hard.
before you paint anything though you have to make sure the surface is free of rust and is clean. the best way is to go over whatever you're painting with a wire wheel on a drill or angle grinder or a grinding disk etc. Also you're best to treat any rusty areas with a rust reverter solution. There are various ones on the market. I can't quite remember what it is I use. (I'm at work at the moment but will look when I get home)
From experience I've found it useful to etch prime the surface before you paint it too as it just gives that added bit of protection, the paint goes on easier and you get a better finish.. I know some paints say they don't need primer but I always do anyway.
hope this helps.
good luck
joe
