Sorry to see your car damaged. Just as a pointer for the younger guys, you need to go find a quiet bit of road or a car park, and get used to lifting off when the wheels lock up, ie pump the brakes as they lock up. A lot of these accidents can be avoided pretty easily. You need to practice this so when a panic situation happens it is second nature.
As in
Wheels lock up
Lift off
Brake again
If lock up
Lift off and so on...
But it will be fast action and natural obviously??
Id love to have some driver training for all kinds of situation!! I'm 18 and one of the younger owners of course
Yep - exactly as you said. Basically it lets the tyres grip the road again, once they are locked up you wont slow down much at all.
Try it in an empty bit of road somewhere (so you dont get rammed up the backside), especially on a bit of wet road in a shopping carpark. You will be amazed at how well it works, even if it does feel and look silly. Effectively this is how ABS works.
Another tip that I must admit I didnt know and heard from a driver training day they did for students here - if you are sliding (as in about to spin) - dip the clutch, apparently the action of the flywheel can help to stop the inertia (and must admit it has worked on a slippy bit of road before).
Another obvious but often overlooked one, if you find yourself going too fast into a corner, look at where you want to go - not at the lamppost or fence that you dont want to hit. It is often second nature to steer etc once you focus on where you want the car to end up. How many times have you seen skidmarks leading straight into the only solid thing in the area? That is cause someone thought 'aghhh im going to hit the post!' So... locked up and went straight at it.
One last tip - if you are heading into a corner and have too much speed on, brake, stay wide, turn in late, and at worst you can 'straight line the corner more' and cut off more speed across the corner. You will have a lot more space to cut of speed than if you just drive around the centre of the curve.
If you can afford it - get along to a skid pan, a race day or a gymkhana (if thats what you call them). Getting used to speed and what to do when it all goes wrong is a great way to improve normal driving skills, and lots of fun.
Edited by CobraV8, 30 September 2012 - 08:53 AM.
