Race Car Cornering Grip Vs Youtube Incar Vids
Posted 07 October 2012 - 07:38 PM
Since day one i have been batteling with understeer in slower corners and have changed to Dunlop D93's for more grip. It feels that it did not help much, but I do not like a loose back and therefore not to keen to get an anti roll bar as yet. Running 2 deg neg camber in the front 0.5 at the back. So I've decided to live with this for now.
The problem now is that when I go through faster corners, it feels like the car is sliding a lot sideways. It is understeering to put it blunt, but I can feel the car losing grip sideways. sometimes I have to slack down around the corners due to other cars, and usually loose the back end totally even by just lifting off the accelerator. Now I brake so early in corners to allow faster cars through that my lap times decreased by 2 sec. I do have some body roll, but not to much.
I have watched some in car vids on the mini sevens, and it seems they are running with loose backs and just control them well. It looks like they actually loose them, cath it by counter steer and just accerate again. On that, the corners I talk about, I am usually with pedal to the metal and pulling through the corner, or so I think.
Is this the way to race a mini ie do I need to improve my ability to 'drift/bounce' the car around a corner or am I missing something ?
Posted 07 October 2012 - 07:43 PM
Posted 07 October 2012 - 07:50 PM
Front
Toe out 1.6mm
Camber -2
Caster 4
Rear
Toe in 1.6 m
Camber -0.5
Car has not been lowered excessively and back is about 3/4" higher than the front. Dampers in front is about double as hard as the back's settings.
As mentioned, the problem feels to be the lack of sideways grip, ie turning more does not help and the car just skid sideways. Might be that I enter the corner to fast ?
Posted 07 October 2012 - 07:59 PM
I do not mind to purchase rose jointed lower and tire rods from minispares, I'd that is what I require !! I just want to stop wasting money on parts and setup that does not work, or spent the time and learn how to drive the car properly.
Is it normal for the mini's back to break away in a corner when de-accelerating or braking ??.
Posted 07 October 2012 - 08:03 PM
Posted 07 October 2012 - 09:59 PM
If you lift off mid corner then you will loose it. Commit more, if they are faster, let them find their own way around!! Don't let them make you compromise your own time just to let them through!!!
Anyway, it's a front wheel drive, the rear just follows!
Edited by Artful Dodger, 07 October 2012 - 10:02 PM.
Posted 09 October 2012 - 12:28 PM
i too do not like the rear stepping out.
what championship do u run in
what engine and diff
tyre size.
the fastest way around a corner in a mini is to have it set up like a mini seven/miglia. but when racing with other cars its no so easy. as they are normally slower through the turns which sometimes make it inevitable to lift. at this point a mini will spin.
always always keep your foot down on a bend, and the rear will not overtake the front.
tell me what spec your car is and i may be able to offer advise.
see me race
Posted 09 October 2012 - 02:47 PM
rear ARB, and a few other bits
yes they are unstable, and yes there is a skill in driving them... its balancing the power and steering input... remember the more you turn the wheel: the more speed you burn off... make the back end help you around the corner and you need less steering input and can control it on the power...
Edited by icklemini, 09 October 2012 - 02:50 PM.
Posted 09 October 2012 - 03:35 PM
Posted 09 October 2012 - 05:40 PM
I am running a 1330 for now with a standard 3.44 diff in classic car racing or historics. I am running the Dunlop d93 semi slicks 165/70/10.
I am in the process to build a 1430, but for now rather want to spent the money to optimize the suspension and handling of the car. Only once this is sorted I will complete the new engine build, with sc gears and a LSD.
As per your suggestion and my original question : what is the setup of the mini sevens ?? As mentioned my problem is the lost of grip in the sideways direction around a corner ie understeer, I think, although I have lost the back plenty times around the corners.
Posted 09 October 2012 - 05:43 PM
I was told that an anti roll bar on the rear makes the back more loose ?
The setup of my car is as per previous advice from you are cooper man. Wonder is the LSD will make a big difference for holding around the corners ?
Posted 09 October 2012 - 05:54 PM
i take it you played with tyre pressure
when using falkens we had to run 39 f 36 b
and srubbed down to 2mm
Posted 09 October 2012 - 05:55 PM
Racing bob,
oh and with the falkens we had to run 3 deg camber
Posted 09 October 2012 - 06:19 PM
It feels like when the dun lops get to hard, that they loose even more grip. Between a rock and a hard place.
