The oil will start to shear down in literally minutes and with oils you get exactly what you pay for. If you pay more then it will contain better quality, and stronger, additves that will resist shear for longer.
At £15 a bottle (for 4-5 litres) then should be fine just check the specs on the side. It's more the £2.99 stuff that you should avoid like the plague !!
AND of course if you go for even more expensive then you get into the Synthetic region which is a whole different argument again !!!!
For example I changed mine this morning and used Duckams 20W/50 which I plan to do about 6,000 miles on and it was £10.99 !
