Odd Question, Can I Run 2 Brake Master Cylinders?
Posted 09 November 2012 - 08:36 PM
Posted 09 November 2012 - 08:39 PM
Posted 09 November 2012 - 08:44 PM
Posted 09 November 2012 - 08:56 PM
Cheers shifty, milners seem to come up a lot, so will give them a ring Monday.Try googling "Fiddle brakes" they are used on hill climbers!!
Edited by Tamworthbay, 09 November 2012 - 09:41 PM.
Posted 09 November 2012 - 09:03 PM
Edited by sledgehammer, 09 November 2012 - 09:31 PM.
not very commom in minis i guess but the principle is the same
Trac
Posted 09 November 2012 - 09:13 PM
must be a pretty common thing, i think it's a legal requirement in learner cars to have dual controls in the uk
Not a requirement no, but not seen a driving instructor's car without them - I certainly wouldn't teach someone to drive I didn't know without a brake pedal!
Posted 09 November 2012 - 09:39 PM
with a tee piece in the circuit , the fluid would flow from one master cylinder to the other - the easiest route
you need He man dual controls for classic mini - although I can't find them for the classic mini
and sadly the have to be fitted by a trained technician in dual controls if used on the road
but sounds like you are using in a car park situation ? - so I doubt there is any problem with fitting yourself
Edit - some master cylinders may allow the use of a tee - but the mechanical pedal box cross bars would be the safest way IMHO
I have already thought about that, by replacing one reservoir with a bleed nipple i could prevent back flow into that reservoir and provide a mechanism to bleed that part of the system. The pressure is constant throughout the system as is the nature of hydraulic systems. I was concerned about back pressure on a master cylinder piston, but when you think about it, that is exactly what happens as soon as you press the pedal so that isn't an issue on the 'passive' one.
Trac
It was very common indeed on minis up to about 15-20 years ago. Nowadays no-one makes one and I have completely failed to track down one. Surely someone must have one sat in a garage somewhere? I have asked bout a bespoke fitment and got price guides of approximate 2k, which is about 1.9k over our budget! I could make a mechanical one, but the more I think about it, the more I think the hydraulic route appeals as pretty much all the bits are off the shelf, and I have 2 spare master cylinders. It doesn't need to be road legal as the lads driving it will be 12-16, but it must be MSA complient and TOTALLY safe.
Posted 09 November 2012 - 09:47 PM
maybe with the fiddle cylinder as mentioned above
I would fit the pedal box - then see how difficult it would be - either way
as you say 20 years ago - very common - they will turn up on ebay one day
also fit a big red kill button
Edited by sledgehammer, 09 November 2012 - 09:54 PM.
Posted 09 November 2012 - 09:55 PM
OH YES!!!!!! I have a couple ready and waiting to go in. To be fair they drive our electrics cars which do 40mph with up to 80 others cars on track and we haven't had an accident which has been our fault in over 2000 miles of racing. They are very careful and generally listen to instructions better than most teenagers.also fit a big red kill button
Posted 09 November 2012 - 10:03 PM
Trac
whys that then? did people learn to drive in mins? i guess so because theres no end of learner BMW minis about....
also your school sounds awesome..!
Trac
Edited by tractor, 09 November 2012 - 10:05 PM.
Posted 09 November 2012 - 10:07 PM
Thanks mate, link to our latest newsletter if you are interested: http://www.tworivers...r/74/144348.pdf
Trac
Trac
Posted 09 November 2012 - 10:11 PM
Posted 09 November 2012 - 10:30 PM
brilliant mate love what your doing
ps i'm gunna pinch that joke " we knew a man who made a wooden car but it wooden go"..!!! -brilliant
Trac
Posted 09 November 2012 - 10:53 PM
best of luck
