Odd Question, Can I Run 2 Brake Master Cylinders?
#16
Posted 10 November 2012 - 03:10 AM
Afraid it is, the reservoir is open to whole brake circuit with your foot off the pedal. The master cylinder piston passes the drilling to seal off the reservoir before any hydraulic pressure can be built up. Simple one way valves won't work as the fluid needs to return to release the brakes.
To do it hydraulically you'd need a tandem circuit pressure differential valve, like fitted to the first dual circuit systems 13H5848, 13H5905 or RTC2525. Alternatively, rig up a slave to push the driver's master, shouldn't be too hard with a later type horizontal master and a clutch slave. Master & slave should be as near the same bore size as possible.
Plan B would be to connect the outlet of one master into the reservoir connection of the other, you'd need one cylinder to have a suitable "high pressure" reservoir connection. I'm not sure how it'd behave if both pedals were pressed, and being linked in series would double the risk of failure.
#17
Posted 10 November 2012 - 06:14 AM
When the brakes are not pressed they allow brake fluid to pass from the system to the reservoir freely, the basis for the one person bleeding systems. With it set up this way the brake master with the pass through would be the the overriding brakes and would work irregardless of how the reservoir ones were pressed.
You would likely want the reservoirs on the student side and the passthrough on the instructor side so the instructor could always override and brake and the student pressing the brake when the instructor had it pressed would not do much of anything.
NOTE: I have not done this and testing would need to prove it's reliability, but knowing the cutting brakes on my sandrail, would be the least expensive and easiest way to set it up.
Chris
P.S. Bleeding would be easy, just ignore the pass through master cylinder.
Edited by CLM, 10 November 2012 - 06:15 AM.
#18
Posted 10 November 2012 - 07:25 AM
However, there is a somewhat elaborate way of making it work. I am basing this on aircraft practice, mostly medium size turboprops, where in some cases the pedals drive simple hydrostatic master cylinders, each plumbed to a slave cylinder which applies pressure directly to the proportioning valve in the pump-driven part of the system. You can't use an aircraft proportioning valve in a Mini (not a pumped system, and you would have major problems finding slave and caliper seals which were compatible with mineral oil or Skydrol), so youhave to fake the same thing with bits that you can get. You need three master cylinders, and two slaves having equal diameter and stroke. Each master cylinder is simply plumbed to its own slave, the slave having a bleed nipple of course. Both slaves are arranged to push against the third master cylinder, which is plumbed into the brakes in the usual way, but which can be located somewhere convenient, as it is not connected to the pedals. You will need a very rigid frame to mount the two slaves and the main master cylinder, and as it will probably be impossible to find small-diameter, large stroke slaves, you will need some kind of lever to adapt a larger diameter, short stroke slave to the standard master cylinder travel. It is vitally important that either slave can push the master through its entire stroke. You do not use a linkage like a balance bar in reverse, the slaves need to operate such that the one which is pushed farthest wins. I would guess that clutch slave cylinders, with a lever to step up the stroke in the correct ratio, would be the easiest things to use, as they have about the same volumetric displacement as a master cylinder. Wheel cylinders are much too small.
#19
Posted 10 November 2012 - 09:16 AM
#20
Posted 10 November 2012 - 09:43 AM
must be a pretty common thing, i think it's a legal requirement in learner cars to have dual controls in the uk
not very commom in minis i guess but the principle is the same
Trac
It was very common indeed on minis up to about 15-20 years ago. Nowadays no-one makes one and I have completely failed to track down one. Surely someone must have one sat in a garage somewhere? I have asked bout a bespoke fitment and got price guides of approximate 2k, which is about 1.9k over our budget!
Have you tried asking 'old' driving instructors for an 'old' set of dual controls?
A minute online found both http://www.adinews.co.uk/ and http://www.ukdic.co.uk/ . I bet you wouldn't even have to pay to advertise! They have space to fill and I suspect if you told the story to their editorial staff, they would run a nice piece about your charity and the kids you are teaching and that would put the word out that you're looking for that old set of dual controls that someone has at the back of their garage.
#21
Posted 10 November 2012 - 09:50 AM
Trac
Thanks for suggestion i will have a look on those. I have asked around and had a request posted on a forum and up on the walls of the local test centres. It seems that generally the cars are just sold on, usually part ex against the new car. I guess the dealers would just bin them and attempt to hide the fact they were driving school cars. There must be one sat somewhere but finding it is beating me at the moment. I keep an eye on eBay, but then who would think of using a mini for a driving school car today? So will anyone bother trying to sell one? I will keep looking but want to have another system planned in case it doesn't happen.
#22
Posted 10 November 2012 - 10:01 AM
Good suggestion.
Failing that, could you not fabricate your own set of dual controls? Fit another pedal box in the passenger side, and then link them link somehow link them to the main pedals?
#23
Posted 10 November 2012 - 11:05 AM
We have looked at that, but school insurance is a bit strange. We can build a car from scratch and race it with no problems, but 'modifications' to an existing one are a different matter. It may end up with us doing that and getting it signed off by someone in the know as it were. Just looking at all the options really. The issue with home fabricated stuff is how to test it for an extreme situation. By using a dual hydraulic system we would be using components that have all been proven to work, e.g master cylinder, LHD pedal box etc and it would be easier to convince them. The best solution will be to find a set of proper dual controls, but I need a backup plan in case that fails.A minute online found both http://www.adinews.co.uk/ and http://www.ukdic.co.uk/ . I bet you wouldn't even have to pay to advertise! They have space to fill and I suspect if you told the story to their editorial staff, they would run a nice piece about your charity and the kids you are teaching and that would put the word out that you're looking for that old set of dual controls that someone has at the back of their garage.
Good suggestion.
#24
Posted 10 November 2012 - 11:16 AM
#25
Posted 10 November 2012 - 11:55 AM
As for the lathework involved in making certain parts of it, by using 27mm ID tubing you could use the standard bushes, and drill and tap both ends of 14mm bar for the central rod.
If this is something you end up looking at more closely, drop me a pm, as I'm currently doing it to my mini (like in the link above, but mounting the servo slightly further left, on the LHD brake mounts).
#26
Posted 10 November 2012 - 01:40 PM
http://www.somerford...page=page&id=58
It would be easier to make the whole car LHD, or automatic.
#27
Posted 10 November 2012 - 03:37 PM
#28
Posted 10 November 2012 - 03:44 PM
i know i've had to resort to knocking it out of gear and the handbrake as a passenger before now
trac
#29
Posted 10 November 2012 - 03:48 PM
That could work well, without a tunnel there is plenty of space in the front of a miniI'm thinking that the most common type of dual brake pedals is with a torsion rod from the passenger brake pedal to simply push on the driver's brake pedal. Without permanent physical contact (few mil clearance) it wouldn't even be a modification.
Thanks for the link, machine work is no problem, we have an ex BL toolmaker on the staff (did the tool for mk4 wings many moons ago)If you do decide to make a mechanical setup, here's some inspiration. The principle's the same, you'd just need to keep the servo on the driver's side, and weld three tabs on the long outer tube instead of two.
See if you can find a scrap LHD '88 on Mini, or one that's going to be converted to RHD.
http://www.somerfordmini.co.uk/eshop/index.php?main_page=page&id=58
The holes are already there, which is why I had the idea at first.
In the OPdont forget youl need a dual control clutch as well
#30
Posted 10 November 2012 - 04:10 PM
Follow the link , if you haven't, the post '88 LHD's have a torsion bar & the master still on the right.
