Odd Question, Can I Run 2 Brake Master Cylinders?
39 replies to this topic
#31 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 10 November 2012 - 04:19 PM
The holes are already there, which is why I had the idea at first.
Follow the link , if you haven't, the post '88 LHD's have a torsion bar & the master still on the right.
With you now! The picture doesn't come up as I am on an iPad. Will have a look on laptop later. Thanks
#32 jd24-7
jd24-7
  • 111 posts
Posted 11 November 2012 - 12:26 PM
Is there such a thing as a one way valve which has a small enough bore for brake pipe fitment? Or could one be manufactured to suit this purpose, this way you could have one either side of the tee piece and you could run dual master cylinders as you plan. I have seen two master cylinders running on seperate lines, for the same pedal with much success, not that this will help you in the slightest though!
find a local hydraulic supplier . You Will need to check max pressure and the pressure that makes the check valve operate, but possible. You need to think about fail safe tho. As if the check valve fails, driver and instructor loose brakes.
Edit.
I Dont think this Will work as the fluid May not return to the master cylinder. Maybe if the cracking pressure is high enough on the check valve this Will allow fluid to return from brakes but not at high pressure from dual master cylinders.
Edited by jd24-7, 11 November 2012 - 12:32 PM.
#33 tiger99
tiger99
  • 8,584 posts
Posted 11 November 2012 - 03:23 PM
As I already explained, this can not work.
#34 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 11 November 2012 - 03:28 PM
thought about it some more, and the way i think i would attack this is with a servo brake set up and a bit of engineering with the left hand drive pedal set up.
#35 sledgehammer
sledgehammer
  • 3,098 posts
Posted 11 November 2012 - 07:52 PM
You can get an universal dual control setup -
http://www.dualcontr...co.uk/page6.htm
http://www.he-mandua...general-faq.pdf
I have seen very simple ones with a lever & bracket welded to a torsion rod , in a tube connected to a pedal box
but can't find any pic's
#36 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 11 November 2012 - 08:01 PM
http://www.dualcontrolsleeds.co.uk/page6.htm
http://www.he-mandualcontrols.co.uk/heman-general-faq.pdf
Thanks! The ADI one from Leeds looks perfect. They are a company I haven't come across so will give them a call tomorrow.
#37 sledgehammer
sledgehammer
  • 3,098 posts
Posted 11 November 2012 - 08:06 PM
Google is fantastic - if you know what to ask it
I have a feeling it's going to be £xpensive
I personally would sit & wait on ebay - there were loads of learner mini's in the 60's 70's 80's 90's - maybe not all dual control - but a lot
wishing you luck
ps - you could offer them free ad's on your cars - for a discount
and more info - a bit clearer ...
http://www.dualbrake.com/instafat.html
Edited by sledgehammer, 11 November 2012 - 08:11 PM.
#38 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 11 November 2012 - 08:19 PM
wishing you luck
Take a look at the link on page one to our newsletter, we make sure all sponsors get the recognition they deserve. It's a hard time for any business at the moment so we are very grateful to anyone who helps out. It makes a huge difference to the lives of the kids involved. It has been genuinely life changing for several of them over the years and would not have been possible without the help of some great people who put their hands in their pockets. We still send newsletters to people who helped us ten years ago and are in contact with over 60 sponsors, some big some small. It has ranged from a tenners worth of steel plate to hundreds of pounds worth of bits. They all make a difference. The mini will be well covered in stickers when it's finished! We even got a cheque from our last OFSTED inspector!
#39 tractor
tractor
  • 662 posts
Posted 11 November 2012 - 09:45 PM
I quite belive it,
loving what your doing here, i've read some of your posts before but i didn't realise your set up. i wish there was this sort of thing around when i was at school and i know a lot of other people who would of benifited from it as well
Im based in somerset but if theres anything i can do just let me know,
unfortunatly i'm not too hot on dual controls tho sorry :shy:
Trac
#40 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 12 November 2012 - 04:56 PM
I quite belive it,
Trac
Thanks mate, being a special school we can be a bit more flexible and target what the kids are good at, which is the way all education should be IMHO. Some schools do bits but the curriculum and paperwork is a real killer. I know staff in other schools who are incredibly motivated and would love to do what we do but can't find the time. It is very expensive, which is also a problem. We spend as much time trying to raise funds as we do working on the cars but its all part of the 'team effort'. We have built all sorts over the years including a 2 man hovercraft. The mini is the first resto we have done and we have plans for 2 drive systems on separate subframes that we can change. Got a lead on a big electric motor which I hope will come off!
