Route For Brake And Fuel Pipes.
23 replies to this topic
#16 skoughi
skoughi
  • 1,199 posts
  • Local Club: Shetland classic car club
Posted 02 December 2012 - 08:07 PM
Yep, I did stand back and think why not just make some tabs, plug weld them and heat some shrink fit elec hose. Simples. Job done. But I've got it in my head that I want some nice new p clips on some nice new pipework and I want to do it in a way that will have the least chance of rusting or leaking. I'm afraid I canna turn once I start something until I finish it or can go no further. Some folk would call me stubborn!
Edited by skoughi, 02 December 2012 - 08:14 PM.
#17 skoughi
skoughi
  • 1,199 posts
Posted 02 December 2012 - 08:11 PM
Also there was no tabs on the floor pans I used. ;D
#18 tiger99
tiger99
  • 8,584 posts
Posted 03 December 2012 - 02:55 PM
Well, those are very good reasons! It is nice to have things looking neat and tidy, even if it does take slightly more work. Most of us don't care, to that level of detail at least, but that should never stop anyone who does.
#19 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 10 December 2012 - 03:23 PM
I have these pics saved in my inspiration folder lol - they have brake and fuel lines...
Wow, I'm in someone's inspiration folder! :teehee:
I'm genuinely flattered.
Skoighi. I used stainless P clips with plated M5 nuts and bolts. Most of the P clips are fitted to the sides of the channels which positioned the nuts inside the channels and below the level of the carpets.
Graham.
This is one fit looking under side! I want one!!!!!
#20 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,091 posts
  • Name: Neil
Posted 10 December 2012 - 03:31 PM
Why not weld the studs in place at least that way you will not struggle with doing anything up.
Whatever you do do not use tucker pop or any other type of aluminium rivet, they will corrode and ruin your floor.
#21 skoughi
skoughi
  • 1,199 posts
Posted 11 December 2012 - 07:29 AM
Hi was thinking about welding them on, the holes for them have been drilled so I can put them through from the inside with a couple of tacks. The reason I was thinking to fix them in with a lock nut was in case the set screws get damaged then they can be easily replaced. Maybe Im thinking about this too much, maybe I need to get out more!!
#22 sonikk4
sonikk4
  • 16,091 posts
  • Name: Neil
Posted 11 December 2012 - 02:24 PM
Providing you use a decent quality bolt then you should be fine. make sure if you do go the welded route then use a clad type bolt plus a drop of copperslip.
#23 ClassicAlex
ClassicAlex
  • 80 posts
Posted 18 October 2016 - 10:05 AM
is this what you are after
Graham
Hi,
just sorting out my piping and was wondering what is the left pipe with no attachments for?
Thanks!
#24 MacGyver
MacGyver
  • 1,027 posts
Posted 18 October 2016 - 10:54 AM
Which left?
In the first pic: back brakes on the left and petrol on the right. (picture orientation)
