General overhaul
#91
Posted 04 July 2006 - 06:40 PM
#92
Posted 06 July 2006 - 09:41 PM
As for progress, well thats now in the hands of the suppliers. Waiting on an input gear nose bearing for the gearbox, a primary gear thrust washer, a brake line and a heater valve blank plate. Hoping to get the engine in and running sunday and paint the rest of the panels in the evenings of next week. This may swap about depending on the parts turning up, but looking good for te MOT on friday now. If it fails then I'm going to sack it for getting the car to Avon, but I will still be going
#93
Posted 06 July 2006 - 09:48 PM
1399 spi with turbo added later on?
looking good by the way
#94
Posted 06 July 2006 - 10:59 PM
The turbo SPi will be standard 1275 and is a project not yet started. But, in the mean time there is the 1275 16valve multi point fuel injected turbo sat on the shelf waiting to be finished
#95
Posted 07 July 2006 - 01:25 AM
the engine(S) sounds good especially the 1275 16v turbo thats the beemer head one isnt it?
wayne
#96
Posted 07 July 2006 - 07:08 AM
I assume the gearbox and drive casing are assembled to allow you to measure and set endfloats etc. Can the block be added when they are as shown or do you have to take them apart again?
Will you have to remove the pot joint gaiters to replace the drive shafts? They look freshly installed on the pot joints, but how can you get the inner clip/cable tie onto the driveshaft? Or do you run without that clip/cable tie?
#97
Posted 07 July 2006 - 09:33 AM
The pot joints are pre assembled, the boot attaches to the center rose that the drive shaft slides into, it is a seperateble seald unit, no need to disturb it again, the drive shaft mearly pushes straight into the joint.
#98
Posted 08 July 2006 - 10:49 PM
#99
Posted 08 July 2006 - 11:23 PM
You could just weld on a plate. I did this on the air vent hole in the front panel as one of the bolts for the lamp bracket would be fixed to nothing otherwise
#100
Posted 09 July 2006 - 08:06 PM
#101
Posted 09 July 2006 - 10:13 PM
Didnt have the time to get it running. It seems I am running in to more problems now then I have across the whole project. These just set you back and back. So it will be tomorrow for a run
One thing i am a little concerned about is the oil pressure is 90 psi when cranking over with the plugs removed and new 20w50 Penrite running in oil. Going to wait and see what its like when its running and has warmed up. I did fit a new Ball and spring and did notice that i had to compress the spring quite a bit. If its still a problem, I'll rob the piston and spring out the engine i took out and see if that makes any difference.
Everything works electricaly other than the indicators and the head light flasher. I have changed the stalks as the clip was broken. I got these from Mini and Metro spares in Warrington, so, chances are its the stalk that is actualy faulty, knowing them.
Not going to have the time to get paint on all the doors so will only be doing the bits that actualy need it for now. It'll be a bit of a harlequin of different whites. LOL
#102
Posted 10 July 2006 - 12:22 AM
wayne
#103
Posted 10 July 2006 - 03:58 PM
Got to blead the brakes agian and also the clutch, fit the other driveshaft to the gearbox, tighten up the CV joint nuts and adjust the brakes. Thats the task list for tonight.
#104
Posted 10 July 2006 - 04:11 PM
Nice work! Bet you can't stop grinnin!
Woo!
#105
Posted 10 July 2006 - 04:30 PM
