totally agree with you, do you think it would be a good idea to speak to an MOT garage to confirm that its done in that way?I can't see why an engine should have a new number just because it get's reconditioned! It's still the same block -and that's what the number is attached to. So - just print out the page showing engine numbers against age of cars and take it along with you. The Tester isn't going to be that bothered - as long as he has something believable to look at. The old number should of course have been registered with DVLA to the car - and appear on the V5c and on his computer to make it work.
Mot Engine Age
#31
Posted 13 January 2013 - 07:34 PM
#32
Posted 13 January 2013 - 07:35 PM
If there is no exact match for your car in the emissions booklet provided by VOSA then your car will not require a cat test regardless of what engine it has fitted (providing it is not newer than the car). Unfortunately the engine ID is contained within the VIN of late MG/Rover vehiclesI suppose it's a case of just seeing what happens if I took it with a 1293, but I agree that it depends on who the tester is...
MG ROVER GROUP LTD
The Model Code consists of the 4th & 5th digit of the VIN number and defines the model. The Engine Code consists of
the 8th digit of the VIN number and defines the engine type. The Serial Number consists of the last 6 digits of the VIN
If your car VIN does not match with any of the models below, then you can stick any older engine in and it will not require a cat test or proof of age. However If you do get a match then you must provide a dating certificate/letter.
Mini Model Code XN
1.3l Auto TBi Engine Code X Serial No 059845 onwards
1.3l Manual TBi Engine Code X Serial No 059822 onwards
1.3l TBi Engine Code Y Serial No 060488 onwards
1.3l MPi Engine Code Z
Edited by tommy13, 13 January 2013 - 07:38 PM.
#33
Posted 13 January 2013 - 07:37 PM
The engine conversions fall into the same category.
If the VTEC or VX engine is newer than the car, the emmissions testis based on the age of the car. If the VTEC engine is older than the car, then the vehicle has to pass an emmissions test based on the age of the engine.
I disagree.......
I have never heard of this in the 20+ years of faffin around with cars. I used to re-engine Capri's & Landrovers with different engines and the vehicles were always mot'd with the " age of the car ", not the engine.
Answer me this. Hypothetically, your Ford Mondeo of 1996 vintage blows it engine. You go to Ford and buy a new identical engine and get that fitted ( in 2013 ). Surely the vehicle emmisions are sill determined by the age of the car, not the year the engine was built, otherwise it would be up against 2013 regulations........
Read the MOT manual, it's on car or engine whatever is oldest, which solves your hypothetical problem
#34
Posted 13 January 2013 - 07:39 PM
your 1969 MG midget blows it's engine and you say i have had enough i will fit a K series engine
how will a K series engine mated to a other wise standard midget pass a modern car emissions test with no cat fitted and no where to fit a cat in the standard exhaust
#35
Posted 13 January 2013 - 07:53 PM
#36
Posted 13 January 2013 - 07:57 PM
If the VTEC or VX engine is newer than the car, the emmissions test is based on the age of the car. If the VTEC engine is older than the car, then the vehicle has to pass an emmissions test based on the age of the engine.
I disagree.......
You've disagreed with what I said, and then written a hypothetical argument that is the same situation as what I had stated. You've taken an old car, fitted a newer engine, the vehicle then gets tested to the age of the car instead of the engine, as the car is oldest.
#37
Posted 13 January 2013 - 08:00 PM
through this post some people have been able to read the link to the MOT testers manual and give them the correct information about having a MOT with a fresh engine.
some people disagree about having to have a new engine number if the engine is rebuilt, if some one has a link then we will all believe it, untill then like lots of postings on TMF some people will disagree.
#38
Posted 13 January 2013 - 08:06 PM
or this Hypothetically
It has no need to pass a modern emissions test - the test will be done on what's older of the engine or car so will only have to pass a visible smoke test.
#39
I've only ever based the engine rebuild thing on what I've been told by rebuilders. But I have no idea what actually constitutes a 'rebuild'....surely a slight overbore using standard over-sized pistons (like a 1293) is still an engine of the same spec. that's just been repaired, not rebuilt...that's the grey area.
Most MOT testers would look at a Mini like the one in question and just do an emmissions test based on carb figures anyway!
#40
Posted 13 January 2013 - 08:10 PM
The MOT side regarding which test seems pretty simple though..
The test is done to whichever is older...engine or car.
1972 car 1995 engine test to the cars age
1995 car 1972 engine test to the engines age (with proof)
#41
#42
Posted 13 January 2013 - 08:28 PM
it's a good idea, but if what some people are saying about testing to the oldest year then i wouldn't need to pass emissions for the 'age of the car' as i would acquire an older blockcarry out adjustments to the vehicle to pass emissions for the age of the car.
#43
Posted 13 January 2013 - 08:29 PM
#44
Posted 13 January 2013 - 08:35 PM
#45
Posted 13 January 2013 - 08:40 PM
I disagree.......
Nope..... You said " If the VTEC engine is older than the car, then the vehicle has to pass an emmissions test based on the age of the engine."
I said no, it gets tested in the age of the car...........
This is what has been said to me over the numerous years of doing engine swaps. And to be honest, I have never been asked the age of the engine going back in.
