Flipfront Vs All Panels And Grp Versus Metal One
#16
Posted 15 January 2013 - 10:50 PM
#17
Posted 15 January 2013 - 11:04 PM
#18
Posted 15 January 2013 - 11:16 PM
No of course I'll add bracebars. And will I need to remove any inner wing? to get it to fit? I have a Rivnut kit so may well go that way.
I was more pointing out that some one (possibly a muppet) at the DVLA or VOSA with no knowledge of Minis has allegedly said you can keep your log book if you keep in the inner wings when they are infact useless without the rest of the original front end.
#19
Posted 16 January 2013 - 02:06 AM
Inner wings are structurally useless if they aren't attached to outer wings to form a box. You won't fit a (thicker, GRP) flip front over them without some modification either.
#20
Posted 16 January 2013 - 06:53 PM
You may need IVA, if and when the authorities enforce their own rules, which is apparently not happening right now. Be aware that no Mini, unless extensively modified in many areas, will pass. In the meantime fit proper bracing bars, and preferably a full solid mount kit to the subframe. If you do get into IVA problems, the best bet is to revert to an all-steel front, which is not all that hard. Just refit partial inner wings (the majority remains anyway, from the damper mounts backwards), front panel and outer wings.
I don't like flip fronts due to them giving even less accident protection than a standard Mini, so be aware of its limitations.
#21
Posted 16 January 2013 - 07:31 PM
if you remove large parts of the car and replace with something different it's not the same car any more so why should it keeps the previous identity ?
a lot of people are getting the strength and identity mixed up with these inner wings
Edited by Bungle, 16 January 2013 - 07:32 PM.
#22
Posted 16 January 2013 - 07:46 PM
#23
Posted 16 January 2013 - 07:58 PM
#24
Posted 16 January 2013 - 09:40 PM
no just putting stop to scaremongering and incorrect information
So what you're saying about it lowering the value of mini`s isn't scaremongering and incorrect information.
I`m not sure about your job or the industry that's in, but the industry i work in and in my job role every claim i make i have to substantiate.
Now given what you're saying has no constant you cant compare and thus cannot make such a comment. I wouldn't anyway.
#25
Posted 16 January 2013 - 09:54 PM
a good bog standard mini makes better money than a modified one and it's not me buying the standard ones up to prove a point
#26
Posted 16 January 2013 - 09:57 PM
thus cars with GRP fronts do sell for less
#27
Posted 16 January 2013 - 11:57 PM
just look at ebay and see what sells and for how much
How many flip fronted mini`s do you see for sale on there that are in good condition? Hold that, how many do you see for sale that have a flip front?
Again, not like you can compare is it?
But whatever keeps you warm at night.
Ill just keep commenting every time I see you give what I feel to be misleading information.
http://www.ebay.co.uk/itm/AUSTIN-MINI-1000-AUTO-GOLD-/110998359440?_trksid=p2047675.l2557&ssPageName=STRK:MESELX:IT&nma=true&si=AAMiC2aWdl5rF%2FSJ9mHcNxitgRo%3D&orig_cvip=true&rt=nc
#28
Posted 17 January 2013 - 12:08 AM
One fairly solid and seemingly original car.
http://www.theminiforum.co.uk/forums/topic/205981-1987-austin-mini-city-e-998-1275/page__hl__%2Bflip+%2Bfront
One clean car. Modified flip fronted. Not a GRP front admittedly but somehow i don't think that's going to make up for the £1900 price difference.
People dont tend to like buying a car thats already had a flip front fitted, unless done for weight and performance reasons chances are its been done because its easier and quicker, what else is done quickly or bodged on the car etc etc, I would much prefer to buy a solid car thats not been messed with.
#29
Posted 17 January 2013 - 12:12 AM
I am just working by logic that someone would prefer a clean original car than one thats had a GRP front fitted for no apparent reason as the reason normally is its easier which is a bodge in my books as easier doesn't include the structural work needed
#30
Posted 17 January 2013 - 02:07 AM
You could say you can pass a test without inner wings so they are not structural, or you could say you have to add new structure with brace bars so the original structure has been modified. You can only hope common sense would prevail - an IVA wouldn't assess the structure, without without inner wings or brace bars. It would have something to say about sharp edges on mouldings & sticky out bonnet pins though, so it's probably best to build to a standard that'd pass and make it a moot point.
