Best Oil
FAZ
, Jan 28 2013 03:54 PM
71 replies to this topic
Posted 28 January 2013 - 03:54 PM
had two different people recommend different oils for my 1275 spi
halfords 20w50 mineral oil or 10w40?
what would you recommend
neil x
neil x
Posted 28 January 2013 - 03:58 PM
Ive used that 20w50 oil that looks like green sludge lol when i had my 2 minis, found it to be quite good
and spark plugs for that matter :)
only plan to use the car sensibly and for cruising, so need for high spec plugs and oil :)
Posted 28 January 2013 - 04:14 PM
Def 20/50
Posted 28 January 2013 - 04:17 PM
Oh good lord, here comes the oil debate again! There must have been more threads on here about this subject than anything else!
The majority of people here will recommend a decent quality 20w/50 mineral oil, mainly because as the classic mini engine shares it's oil with gearbox and the closest thing to a thick gearbox oil is therefore needed to preserve the life of the gearbox. Then there are others that will argue that the properties of modern synthetic and semi sync oils are far superior and more than capable of performing that function and so we have the same debate, over and over again!
So sit back, enjoy the debate and be prepared that by the end you will still have no idea which oil to buy!
Edited by AVV IT, 28 January 2013 - 04:18 PM.
Posted 28 January 2013 - 04:20 PM
Every forum Ive been on has always had some form of debate. find it quite amusing.
Posted 28 January 2013 - 04:24 PM
Penrite 20w50 mineral I think is the best as it lasts much longer than the halfords stuff,
Longer I mean it keeps its golden colour for much longer, but halfords stuff is fine and it's green as said above lol :)
Posted 28 January 2013 - 04:25 PM
20/50 mineral
Posted 28 January 2013 - 04:27 PM
for spark plugs i use ngk bp6es
Posted 28 January 2013 - 04:30 PM
Like most service items they never last forever, I use 2050 Penrite oil and brp6es NGK spark plugs and they both are fine for everyday use, this is on a 1275 carb engine by the way :)
Could try Bosch spark plugs as they might be better quality but are more expensive
Posted 28 January 2013 - 04:32 PM
Yep halfords 20w50, to clarify,
FYI, Im not "trying" to be clever
Posted 28 January 2013 - 04:35 PM
i use castrol 20 50 seems to keep good oil pressure
and change every 2000 miles
Posted 28 January 2013 - 05:59 PM
At 2000 miles it should keep good pressure
Posted 28 January 2013 - 06:05 PM
15w-40, 15w-50 or 20w-50 should all do. Most people use the latter because it's generally cheap, easy to source, aimed at classic cars and you can also buy it with gearbox additives (Millers). In reality, anything non synthetic and of those grades should be fine. Just buy quality oil, not cheap rubbish (Wilkinson and Asda spring to mind).
Dave.
Dave.
Posted 28 January 2013 - 06:06 PM
halfords 20w50 for me
