Ive taken the starter motor off and the ignition coil, do i have to disconnect the engine mounts and lift up the engine to take the flywheel housing off?
Clutch plate replacement
Posted 11 April 2006 - 07:00 PM
Posted 11 April 2006 - 07:09 PM
Posted 11 April 2006 - 07:19 PM
couldnt find a small enough philips screw driver to get the solenoid off ill get one tomorrow
Any other tips for changing the clutch plate? ive got a flywheel puller before anyone askes
Posted 11 April 2006 - 07:24 PM
Posted 11 April 2006 - 07:43 PM
You only set the adjustment once in a Verto and if it's a bit wrong now it will get worse over time and can't really be corrected.
umm i thought my clutch wasn't a verto as its an 1985 998cc mayfair or am i wrong
Posted 11 April 2006 - 08:01 PM
Also, when you put the puller on the flywheel, the three bolts that screw into the flywheel, make sure you screw all three in identical amounts.
Posted 11 April 2006 - 08:39 PM
ive always thought it was the other clutch, oh well ill go get a verto one tomorrow
Posted 12 April 2006 - 01:02 AM
it looks like a big hash of different parts to me, inertia starter with wing mounted solenoid is usually a pre-verto setup.
but on the other hand you've got the short verto clutch arm and tilted slave bracket which are for the verto type clutch.
It could be possible that you've got a verto clutch with an inertia type ring gear. or you could have the pre-verto setup with the wrong arm and slave on there.
actually isn't that a metro slave cylinder bracket, i'm sure the one that was standard on my original engine didn't have that half circle thing sticking up off the top of it. Could it be possible that the engines not original? and this could be a case of previous owner syndrome?
Posted 12 April 2006 - 01:47 PM
yes its a verto
the haynes manual says "rotate the crankshaft until the driving slot in the flywheel, located just behind the centre bolt head, is horizontal"
What does this mean?
Posted 12 April 2006 - 02:27 PM
(Thats what I remember from taking my pre-Verto flywheel off last week, pretty sure its the same for Verto, may want to double check though).
Posted 12 April 2006 - 02:45 PM
Verto clutch is '82 on.
Pre-engaged starter is '85 on. There's three years of Minis with Verto clutch and innertia starter.
Lot's of problems arise like this when people assume that there are these huge master change points in production where everything was changed at once. There aren't, Minis evolved gradually.
Also, looking at that photo again there are some screws missing from your Clutch slave plate.
As Jammy says, you should be able to see the slot in the crank if you look around the bolt head. It is very, very important to get this horizontal. Don't skip this step. And make sure you are looking at the slot in the crank, not in the flywheel centre. They should line up but never assume anything unless you built it.
Posted 13 April 2006 - 11:15 AM
Could someone point out the slot in the crankshaft to me and could someone also tell me how to get that washer off so i can get the bolt off i think the last person who did this might have damaged it
Posted 13 April 2006 - 11:22 AM
I would assume the slot in the collar around the bolt would be in line with the slot in the crank, but since this is such a crucial step I wouldn't want to follow an assumption so don't listen to me!
Posted 13 April 2006 - 11:27 AM
I was thinking the same thing jammy but id like to be sureI would assume the slot in the collar around the bolt would be in line with the slot in the crank
the washer inside that coller is damaged too dunno how im gunna get it out
Posted 13 April 2006 - 12:32 PM
