the lock washer is part of the bolt. you need to pry it away with a screwdriver then just get your socket and knock it on to flatten out the lock washer.
as for the keyway i'd personally just get the engine to tdc on number 1 and it should be fine.
to be honest i've never bothered to check the orientation of the keyway when removing flywheels and i've never had a problem. actually when you get the bolt out you'll be able to see the keyway, there's gonna be no chance of your flywheel coming off and the C washer dropping anyway.
another thing to make sure of is once the big bolt is out make sure you remove the keyed washer thats behind it, the one that keeps the flywheel square with the crank keyway. otherwise your flywheel will not budge in the slightest.
Clutch plate replacement
Mini Mad James
, Apr 11 2006 07:00 PM
16 replies to this topic
#16
Posted 13 April 2006 - 12:39 PM
#17
Posted 13 April 2006 - 03:57 PM
Got it off
forgot to use the thrust pad the first time round almost damaged the crankshaft
second time round it came off with a huge bang its much heavier than i thought to be honest
also found the source of an oil leak is it easy to replace the seal round the crankshaft?
