Windage / Baffle Trays Back In Production.
42 replies to this topic
#1 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 21 February 2013 - 06:55 PM
Due to popular demand from various customers I've been out with the cardboard and CAD, and now have the results back from the cutters.
The first batch are for me to first make sure they fit and do the final refinements necessary before they are in full production.
As they will now be laser cut in volume from aluminium sheet the cost has been slashed, with an expected retail price of less than £25 inc VAT.
First pass is for rod change only, but older 4 synchro remotes will not be far behind and 3 synchro's not long after those.
Attached File  2013-02-21-104.jpg   31.91K   167 downloads
#2 Old Bob
Old Bob
    TMF Menber Passed On R.I,P
  • 825 posts
Posted 21 February 2013 - 07:11 PM
Please include one in the box you are currently doing for me please John.
Kind regards,
Bob
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 21 February 2013 - 07:16 PM
I'll leave that one in there then ;)
That's your box, I needed one which was part built to test the fit..
#4 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 21 February 2013 - 07:50 PM
I was going to knock one of these up for myself.
If they're going to be a decent price then I will probably take 3 :D
#5 tadleysimon
tadleysimon
  • 1,458 posts
  • Local Club: basingstoke mini club
Posted 21 February 2013 - 08:24 PM
at the risk of sounding like a fool. whats the benefit of fitting one of these?
#6 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 21 February 2013 - 08:34 PM
Helps to stop the crank from 'swimming' in the oil from the sump, sapping power =]
#7 rally515
rally515
  • 3,848 posts
Posted 21 February 2013 - 08:55 PM
& you can say that you have a baffled sump which makes you sound cool ofcourse :lol: a bit like a handbrake is for a man to impress women (top gear quote ;D )
#8 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 21 February 2013 - 10:18 PM
Great idea and bargain price! Plan to rebuild an engine fairly soon so this is now on my list!!!
#9 100ev8
100ev8
  • 622 posts
Posted 21 February 2013 - 10:47 PM
how are they secured ?
#10 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 21 February 2013 - 11:40 PM
4 x M5 pan head screws to maintain its position, 3 through the back of the case and one into the main web. You can see the pre-made holes in the tray. The tray itself by the nature of the curve tends to lock itself into a stable position
#11 crazirob
crazirob
  • 650 posts
Posted 24 February 2013 - 09:56 PM
once these are done mate ill have one :D
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 06 March 2013 - 02:37 PM
Prepare yourselves for this....
The final samples are in and they look awesome, and the fit is even better...
Attached File  2013-03-06-118.jpg   62.91K   107 downloads
Now with full rounded shapes and cut outs to prevent cracking, redesigned oil returns for greater strength, and preshaped to the optimum curve for fitting and stability.
Price still to be confirmed, but will be less than £20 + VAT
Will be supplied with 4 x M5 Stainless Panhead Screws for fitting, looking into costs of drill & tap for those which don't have them to hand.
#13 rally515
rally515
  • 3,848 posts
Posted 06 March 2013 - 02:45 PM
is there any risk of the skrews shaking out due to vibration atall ?
Im not at this stage with my engine project yet (still do the mini blah blah blah) but i'l have one if there still around when im at that stage.
#14 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 06 March 2013 - 03:32 PM
I use loctite to prevent that unlikely eventuality.
The reason the price is not set yet is because I'm working on getting a full sheet cut, which should produce between 70 and 80 trays, so there's not going to be a shortage. Once I've negotiated a price I can the set the retail price which has already been brought down from almost £50 a unit to below £20.
#15 crazirob
crazirob
  • 650 posts
Posted 09 March 2013 - 11:32 PM
Will these suit a central oil pickup ?
