Windage / Baffle Trays Back In Production.
42 replies to this topic
#31 Miniac86
Miniac86
  • 334 posts
  • Local Club: MOCKZN
Posted 30 March 2013 - 09:10 AM
Would you be willing to ship internationally? ( South Africa & a total price shipped )
I'm already running a lightened, balanced and knife edged crank, so the use of a windage tray would just assist my motor to rev up a bit more freely.
#32 clivemk1mini
clivemk1mini
  • 1,064 posts
Posted 07 April 2013 - 12:04 PM
Hi can you let me no when there finalised as I will take one and probably one of you centre pick ups as well so it all works nicely together
#33 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 07 April 2013 - 01:37 PM
Oooh... I didn't forget about these but been busy arse farting about...
ANYWAY.....
Latest batch are here.... and with a little bit of patience, provide clearance on both 998 and 1275 rods and the gearbox, but I must say, don't drop one in an expect it to clear first fit you may need to move it around before committing to drilling the holes...
Attached File  2013-04-07-182.jpg   54.33K   20 downloads
#34 Tupers
Tupers
  • 4,176 posts
Posted 07 April 2013 - 04:22 PM
Have you got a batch ready to go out the door yet? My paypal finger's getting itchy. :shifty:
#35 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 09 April 2013 - 10:37 AM
Now available £19.99 inc VAT
http://www.guess-wor...play.htm?id=356
ps.. Domestic shipping is priced for royal mail 'medium' parcels, as that what my system caters for, however will be sent as a small parcel so expect a refund on shipping costs, just I can't get the system to do it for you.
pps.. Yes will ship worldwide
ppps.. 6 in stock, 40 more in the pipeline.
Edited by Guess-Works.com, 09 April 2013 - 10:40 AM.
#36 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 10 April 2013 - 03:44 PM
5 in stock
#37 Tupers
Tupers
  • 4,176 posts
Posted 10 April 2013 - 08:18 PM
I shall now commence sitting next to the door waiting for mine to arrive. :D :D :D :D :D :D :D
#38 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 10 June 2013 - 02:01 PM
While fitting a tray to a gearbox I had one of those epiphany moments, where you wonder, why didn't I think of that before.
A couple of bends later, the trays now sit a lot lower in the case and hence provide a lot more clearance for the crankshaft.
Attached File  2013-06-10-272.jpg   31.46K   22 downloads
I have also now finished the fitting guide....
http://www.guess-wor...ech/windage.htm
If any who has already purchased one, I can provide a template for the location of the bends, or if you wish return your tray and I'll bend it for you.
#39 crazirob
crazirob
  • 650 posts
Posted 11 June 2013 - 10:20 PM
Wishing I got mine now :-(
#40 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 12 June 2013 - 07:15 AM
I assume you have it fitted now and in the car... ??
If not then as I said above, return it and I'll bend it for you.
#41 CobraV8
CobraV8
  • 991 posts
Posted 12 June 2013 - 07:30 AM
I have a 1410 long stroke crank. Is it likely that the wind age tray would clear?
#42 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 12 June 2013 - 07:45 AM
Good question...
And it all comes down to this question back at you...  Did you have to modify the gearbox case for the conrods to clear ?
If not, then there's a good chance it'll clear without modification.
No 2. conrod passes right along the length of the main web in the gearbox, the tray is designed to sit below the arc of this main web.
This can be seen in the fitting guide...
Edited by Guess-Works.com, 12 June 2013 - 07:46 AM.
#43 CobraV8
CobraV8
  • 991 posts
Posted 20 June 2013 - 07:05 AM
I didn't build it, but I know that there are some notches ground into the gearbox for clearance.
