Subframe Mounts: Solid V's Poly
12 replies to this topic
#1 SAL 821X
SAL 821X
  • 1,890 posts
Posted 01 March 2013 - 11:33 AM
A question in another thread arose about whether it's best to fit rubber or solid mounts to the front subframe.
I commented that I intend to have solid toe board mounts and poly tear drop mounts. This was brought to my attention by a couple of people that this isn't the comman thing to do.
I'm sure though that I read some where that it is possible to have the setup I intend to use.
Is this the case?
matt
#2 jaydee
jaydee
  • 8,565 posts
Posted 01 March 2013 - 11:38 AM
Poly teardrop mountings, the thick ones, are so bad that neither minispares sells them...
#3 abe46
abe46
  • 431 posts
  • Local Club: South Devon Mini Club
Posted 01 March 2013 - 12:18 PM
All solid mounts or all rubber mounts.
No compromises in between.
#4 jonny f
jonny f
  • 1,492 posts
  • Local Club: Boxhill Mini Club
I had solid top and teardrop with just the standard rear ones and it worked well.
#5 SAL 821X
SAL 821X
  • 1,890 posts
Posted 01 March 2013 - 12:26 PM
Sorry I meant these ones.
http://www.minisport..._SPDSP668A.html
not the tear drop ones.
#6 abe46
abe46
  • 431 posts
Posted 01 March 2013 - 12:33 PM
This has been covered plenty of times on the forum buddy, the safest is to go all solid or all standard;
http://www.theminifo...vs-poly-bushes/
http://www.theminifo...v-poly-v-solid/
http://www.theminifo...ubframe-mounts/
http://www.theminifo...framecan-i-mix/
And plenty more to list...
Hope this helps
#7 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 01 March 2013 - 12:35 PM
I've run solid towers and teardrops with rubber floors for years with no problems on a couple of cars, but recently solidified the floors too and wish I'd done it years ago.
The handling is soooo much better and there is little increase in NVH.
Poly mounts or bushes are crap imho. Unlike rubber, poly just doesn't have the resilience to continuous compression and fails quickly.
#8 samsfern
samsfern
  • 5,243 posts
Posted 01 March 2013 - 01:29 PM
Solid or poly or rubber, dont mix them, thats when problems arise.
#9 SAL 821X
SAL 821X
  • 1,890 posts
Posted 01 March 2013 - 02:09 PM
Right then just read all the info and it looks like I'll be pulling the subby out again to take the poly bushes out and ordering solid ones.
How thick would you suggest the sheet for the spreader plates should be?
#10 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,177 posts
  • Name: Neil
Posted 01 March 2013 - 02:11 PM
1.2mm should be good enough but if not some 2 mm will be better.
#11 abe46
abe46
  • 431 posts
Posted 01 March 2013 - 02:20 PM
I have got some solid mounts to sell, all apart from the teardrop ones. PM if you are interested buddy, just few of the bits leftover from selling my project.
#12 jaydee
jaydee
  • 8,565 posts
Posted 01 March 2013 - 02:26 PM
Ah ok, they're probably better than the round ones which become like this after a few k miles:
But i'd say to not mix different mountings
#13 jaydee
jaydee
  • 8,565 posts
Posted 01 March 2013 - 07:40 PM
No they've been fitted to the later subbie, its just they cant handle the side movement between frame and bulk and neither the compression between them, hence the shape impressed in the mounting
