Will Not Start
42 replies to this topic
#16 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 11 March 2013 - 09:50 AM
have a look here, not a mini but the principle is the same, you can get the resistance figures from the workshop manual (widely available as a download)
#17 liam_italian
liam_italian
  • 1,417 posts
Posted 11 March 2013 - 11:00 AM
Check all your electrical connections including the engine earth strap, 9/10 it's normally something simple.
#18 Mikalv
Mikalv
  • 39 posts
Posted 11 March 2013 - 11:17 AM
Will do, thanks for all your input. Will post back when (not if) I find the source..
#19 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 11 March 2013 - 12:00 PM
always sound advice this. you should make this part of any routine checks you do even without any problems.
#20 Ipod
Ipod
  • 2,024 posts
Posted 11 March 2013 - 04:17 PM
is it turning over, but just not sparking?
Are you battery connections done up tight, as just placing them on the terminals will cause you grief
#21 Mikalv
Mikalv
  • 39 posts
Posted 11 March 2013 - 09:42 PM
Turning over just fine but no spark. The connections wasn't done right I'm afraid, so Ill make shure to check that as well.
#22 nev_payne
nev_payne
  • 2,249 posts
Posted 12 March 2013 - 02:07 PM
Update on mine - again this morning there was turning over and no spark. The only correlation to this and the other week is the freezing temperatures.
I've ordered a new coil pack regardless, going to check the grounding points aren't undergoing some kind of contraction away from the shell when the temperature drops this low.
#23 Mikalv
Mikalv
  • 39 posts
Posted 12 March 2013 - 02:45 PM
Heading out to the garage now, will post my findings later on. Seems that the coilpack is a well know source for grief..
#24 Mikalv
Mikalv
  • 39 posts
Posted 12 March 2013 - 08:32 PM
Ok, back from the garage:
Removed the grille and cleaned the connection to coilpack and other wires.
Replaced the battery width a fully charged
Cleaned most of the earth connections also in the booth
Result: When everything was apart and I was about to give up she started. I cranked a couple of times and she started every time! Put everything back together, even took the time to re-wire the extra lights. And When everything was in place same damn problem.
Ideas? Bad coil pack? I was unable to measure it since I didn't have the correct bit for my tools.
#25 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 12 March 2013 - 08:42 PM
sounds like it could be a bad conection or wiring somewhere i recon. maybe the cableing is breaking down and you cant see it as its covered. trying moving the cables a bit with each attempt of starting see if that highlights something. you still need to check the coil that as above.
#26 Mikalv
Mikalv
  • 39 posts
Posted 12 March 2013 - 10:22 PM
Shot a short video, immobilizer seem to disable just fine.
Next up, coilpack check.
Edited by Mikalv, 12 March 2013 - 10:24 PM.
#27 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 12 March 2013 - 10:45 PM
well that confirms its not the imobiliser, the fact your actually able to crank the engine rules this out.
#28 Mikalv
Mikalv
  • 39 posts
Posted 12 March 2013 - 11:10 PM
Yep :)
#29 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 16 March 2013 - 09:38 PM
see here for how to check the coil
http://www.theminifo...oil-pack-check/
#30 charie t
charie t
  • 3,153 posts
Posted 17 March 2013 - 09:48 AM
Have you tried turning the key?
