Twin Hs4 Cabs Hitting Bulkhead
Posted 17 March 2013 - 06:20 PM
I have a pair of SU HS4 carbs on a SPC manifold fitted to my 1330 engine in a 1967 mini.
The problem I have is the fuel bowels are fouling on the bulkhead.
I have a couple of ideas to overcome this:
1) replace to and bottom engine steadies with adjustable ones. Cost will be fairly high thought at about £60 inc del
2) figure out how to move the carbs closer to the engine. The is a fairly thick insulating spacer between the carbs and manifold so could get thinner ones, but where from? And/or machine the carb face of the manifold,
Any thoughts or suggestion please
Posted 17 March 2013 - 07:08 PM
Posted 17 March 2013 - 07:24 PM
Posted 17 March 2013 - 08:46 PM
Posted 17 March 2013 - 09:21 PM
Edited by KernowCooper, 17 March 2013 - 09:22 PM.
Posted 17 March 2013 - 09:32 PM
Posted 17 March 2013 - 09:34 PM
Posted 17 March 2013 - 09:38 PM
Spacer is 12mm thick. Manifold is aftermarket SPC as stated
Having now removed the carbs, itis the casting flashing on the right hand (looking at the engine) float bowle that's hitting ones the bolts that hold the plate that the heater pipies go tho.
Soi am going to, to start with, remove the flashing and machine the head of the bolt down
spacers are rubber and blackGood point, where are they from? Are the float bowls level? If the float bowl spacers are rubber what colour is on what carb?
Posted 17 March 2013 - 09:44 PM
Can you pull the choke and get the choke tubes to drop fully. this is another area where clearance can be a issue, and striking and bending the tubes.
Posted 17 March 2013 - 09:46 PM
Edited by Dan, 17 March 2013 - 09:50 PM.
Posted 17 March 2013 - 09:53 PM
Posted 17 March 2013 - 10:01 PM
Yeh, float it catching. Yeh rubber is black, will check the other one now
Edited by Petro1head, 17 March 2013 - 10:01 PM.
Posted 17 March 2013 - 10:03 PM
Sorry , black and red would be a pair of adaptors, not black and grey.
you were right first time. black and grey are a pair.
or is it black and red? mind you think you can have both?? will have to check, that's got me thinking now!!!
Edited by ANON, 17 March 2013 - 10:05 PM.
