Help Please, Need To Sort Out The Ice For My Mpi
Posted 24 March 2013 - 11:55 PM
My Q's are -
I need to get some speakers to fit into the original holes in the parcel shelf, what's my best bet? I don't really want to cut the parcel shelf if it can be avoided.
I guess it's worth running proper cables to the speakers. What's the best stuff to buy?
Is it worth fitting an amp? If so I could install this under the back seat and what are the best phono cables to go from the head unit to the amp.
I have considered door speakers but I will be fitting new door cards and am concerened about raining in. The plasic sheet that fits over the door has to seal and fitting door speakers could lead to problems. Then there's the problem of running the cables into the doors. I am sure someone makes a proper seal / grommet to go between the A post and the door frame but as yet I haven't found one
I am not looking for a mega system, just something that sounds decent and in line with modern cars
Thanks for looking and all comments welcome
Pete
Posted 25 March 2013 - 04:30 PM
My Q's are -
Pete
You should probably try out different speakers, as good ones are subjective. However, for a limited budget I would have some JBL GTO 6.5 Coaxials.
Can't help with cables sorry!
Audiophiles will cry for amps until they die, but for a small system often the head unit does the business, really depends on how it sounds to you. Will be expensive too... I find that my Parrot Asteroid Classic does a pretty good job on its own :)
Door speakers can be done, get some old Metro doorbins with 4"s in, they are a straight swap. For grommets, the ones that come with the central locking door kit sold by many are perfect.
Might be a good idea to try and get some sound coming from in front of you to get the 'sound stage' effect.
Posted 26 March 2013 - 11:36 PM
Posted 27 March 2013 - 12:59 PM
http://www.ebay.co.u...=item3f1c91d2b8
I had these in mind though, for half that!
http://www.ebay.co.u...=item4d02a2f03f
Lets wait for some second opinions though, always worth checking! Also try and pop down to halfrauds if only to listen to some of the display systems, as this can be quite subjective
Posted 27 March 2013 - 06:21 PM
The right amp always gets your speakers sounding their best
Like the previous poster said, have a listen and find what you like.
Cable wise "QED micro" is a lovely cheap cable (£2 per metre) that's also nice and thin... Love the sound these make. Again all cables sound different so don't be afraid to try different things. DO NOT NEGLECT SPEAKER CABLE (and signal cable too if you use an amp)
Good luck with your hunt,
B.M.
Edited by BishopMaverick, 04 April 2013 - 12:36 AM.
Posted 27 March 2013 - 10:55 PM
post if any more help required x
Posted 01 April 2013 - 10:08 PM
I have an SPL MF 500 amp but having looked on the net it's a piece of junk. I have however the chance to buy a Kenwood kac 6495. Is this a decent piece of kit? The plan is to run my rear speakers through it
Thanks for any advice
Pete
Posted 02 April 2013 - 11:41 AM
http://www.caraudiod...e-spg-17cs.html
Or
http://www.caraudiod...e-gztc165t.html
Or or slightly more (but defiantly worth it
http://www.caraudiod...gzrc-16xii.html
And on a budget I would pair them with
http://www.caraudiod...e-pmx-f640.html
Or
http://www.caraudiod...-gzia4115-.html
Or for slightly more again
http://www.caraudiod...-gzta4125x.html
These are what I would personally get and recomend considering your price range and desire for best sound quality possible.
Hope this helps
Posted 03 April 2013 - 11:09 AM
How about a NEW set of speakers from a high end UK manufacturer, that retailed for close to £200 when released... for £70?
http://www.talkaudio...e-16-brand-new/
Not my ad by the way, and at that price you better be quick.
review, http://www.talkaudio...rofile-p16-r197
note Value For Money is a 10... and thats at RRP of £185!
Posted 03 April 2013 - 01:55 PM
Posted 06 April 2013 - 10:03 PM
Again, thanks very much for your help
Pete
Posted 07 April 2013 - 08:01 AM
Posted 09 April 2013 - 10:02 PM
BishopMaveric, some of those speakers you posted links to look very tasty, hope I have done the right thing with the Genesis 16's.
IMO they are a lovely sounding speaker set, but the installation like any speaker is important to insure they sound there best.
i think you did very well, courtesy of Mr. Ruckus's link, they are not only a lovely sounding speaker (if they are the ones I'm think of) but also rather porny in a sublime classy way (like say Audrey Hepburn or Emilia Fox)
you have done well
I would only recommend what I would use myself, taking into account budget, however its most important you find what not only sounds good but also what makes a sound you like... I am yet to find two speakers that sound the same.
Let us know how you find your new speakers
BM
Posted 12 April 2013 - 10:26 PM
Some pics
Head unit. I bought this because it has USB and I had an Alpine system in my first car, which of course was a Mini, that was over 30 years ago, EEK!
These are the speakers for the rear. I assume it's best to fit the tweeters in the back parcel shelf?
From what I have read, these speakers are better with an amp on them, so I have bought this 2000w 2 channel amp from the loudest. Hope I made the right choice!!!
The plan is to fit this under the rear seat
Also got these pods for the front
Not sure they will deliver enough bass as the back is open. If I do use them they will be re furbed with some proper covering
It's all work in progress but hopefully I have the rears sorted now.
Again thanks for your help
Pete
Posted 12 April 2013 - 10:42 PM
