(Insert Swear Word) Hub Nut
#16
Posted 29 March 2013 - 04:38 PM
#17
Posted 29 March 2013 - 04:44 PM
#18
Posted 29 March 2013 - 04:46 PM
#19
Posted 29 March 2013 - 04:54 PM
#20
Posted 29 March 2013 - 05:00 PM
get somone to stand on the brakes while you undo it, fof you cant get it undone like that with a long breaker bar then cut it off. I presume the new cv comes wit a new nut?
No you do not get a new CV with the nut, however if you buy a new CV you do get the nut as the CV is considerably dearer than the nut, also you will probably find that the CV has a step on the shaft and could be scrap anyway, also check the outer's within the hub if there is any slack it's a new hub as well.
#21
Posted 29 March 2013 - 05:10 PM
put spare wheel on set it on ground got someone to sit in it holding brake
put it in gear
and ended up breaking the socket.
the car has always been well maintained and the cv's etc where checked when it was restored. the shafts have been out to change the oil seals about a year ago. dont know what to do now.
#22
Posted 29 March 2013 - 05:18 PM
Maybe take it to a garage (if you know someone the better) and get them to gun it off
#23
Posted 29 March 2013 - 05:21 PM
#24
Posted 29 March 2013 - 05:32 PM
someone must have loved thier airgun at some point.
yea must have been fond of the gun
that's the absolute last resort ATM, no insurance or tax atm and where i live is a cop hotspot.
#25
#26
Posted 29 March 2013 - 05:42 PM
Give me a lever long enough and a fulcrum on which to place it, and I shall move the world. - Archimedis
Basically, if you still can't get it undone. Go by a bigger breaker bar, or get a piece of scaffold pipe and use it as an extra bit of leverage.
#27
Posted 29 March 2013 - 06:22 PM
#28
Posted 29 March 2013 - 07:10 PM
#29
Posted 29 March 2013 - 08:48 PM
#30
Posted 29 March 2013 - 09:19 PM
+1 on the heat. I have an ally scaffold tube with one end cut off. It's surprising how much it will bend before the nut finally releases sometimes. Hub nuts shouldn't be THAT tight so worth giving a really good check over once its off. Also be prepared for it to go suddenly and make sure knuckles, knees etc etc wont get walloped when it does finally go.might have loctite on it, try heating it up
