(Insert Swear Word) Hub Nut
#31
Posted 29 March 2013 - 09:24 PM
I've seen a lot of damage to the nut and conical washer along with the tapered seat in the flange before now on knackered bearings. There is a possibility that it's chewed itself up a bit and is all seized together I guess?
3/4" breaker bar and socket required. Where abouts are you?
#32
Posted 29 March 2013 - 09:29 PM
They won't break half as much as your normal Chrome Vandium ones. If at all.
#33
+1 on the heat. I have an ally scaffold tube with one end cut off. It's surprising how much it will bend before the nut finally releases sometimes. Hub nuts shouldn't be THAT tight so worth giving a really good check over once its off. Also be prepared for it to go suddenly and make sure knuckles, knees etc etc wont get walloped when it does finally go.
might have loctite on it, try heating it up
These can be torqued up and then the holes are aligned so what might be the correct torque figure is then increased to fit the pin in. and it is always (or should be) harder to undo a fixing that to tighten it up.
#34
Posted 29 March 2013 - 09:32 PM
Indeed, but do you do yours up with a scaffold pole? I sincerely hope not, therefore it is inherently obvious in my reply that undoing is harder and I therefore am unsure as to the point of your post?????
#35
Posted 29 March 2013 - 09:46 PM
#36
Posted 29 March 2013 - 09:49 PM
Sorry, I was referring to the following "Hub nuts shouldn't be THAT tight so worth giving a really good check over once its off" Have I mis-read your meaning ? and I use a torque wrench
If I have taken it the wrong way please accept my appologies.
#37
Posted 29 March 2013 - 09:53 PM
No offence caused, I just wasn't sure what you were trying to point out. Seems like the OP has tried significant force with no success, suggests to me there may be something else at play or possibly damage. I have never failed to get one off with a 3 foot breaker bar.The scaffold pole is reserved for really awkward buggers, like accumulators spheres on citroens!
#38
Posted 29 March 2013 - 10:10 PM
#39
Posted 29 March 2013 - 10:18 PM
#40
Posted 30 March 2013 - 08:01 PM
Anyway thanks for the suggestions guys
