What's the safest hight I can raise a mini by on hi-los without pulling the drive shafts to bits? The stables is quite rutted and my mini will ground out for sure
1 reply to this topic
Posted 15 April 2013 - 12:10 PM
Posted 15 April 2013 - 12:34 PM
On the Safari Rally in 1967 Rauno Aaltonen had his 'works' Cooper 'S' raised up about 2" above normal ride height and that was no problem. For gravel rallies it is normal to raise the car by about 1" above standard and that is fine. Drive shaft angles are not much of an issue as the suspension height change will not make a great deal of difference to the shaft angles. Remember, however, that raising the suspension will make the camber more positive (or decrease the negative camber) so you may need negative camber bottom arms, followed, of course, by re-tracking of the front wheels.
Also tagged with one or more of these keywords: suspension
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
