There will be some degree of interference fit in the bush/shell and then reamed to size.
One thing still concerning me here is that the cam liners are just too large. Still not clear on which bit is reamed. Are the liners simply pressed into their bores and them milled out to fit the camshaft perfectly? or are the camshaft bores milled out to allow the liners to fit? If it's the first option, there is no way the liners/bearings I have got are going to press into place.
one other thing I would point out is the honing, just to make sure before you put it all back together, did you supply the pistons so that the machine shop could hone to the correct size? how many miles had the engine done prior to the strip?
Engine was on about 65k and the block and pistons are in very good condition. Because of this the original pistons are being used and the bores have only been very lightly honed to give a fresh surface. New, standard size piston rings being fitted, based on machinist's recommendation from the amount of material he needed to remove (i.e. very little).
This sound ok?
Got the oil pump, forgot to list it. Not familiar with oil gallery plugs. I've searched minispares and it says they are only used on pre-1985 motors? (block is an A+ from 1999/2000). Core plugs have been replaced.From the above, you have missed a new oil pump, a set of oil gallery plugs & a timing chain.
Is timing chain a useful, recommended or absolutely necessary change? This is one part I haven't got yet.
When stripping the block, pistons were pretty much flush with the deck at TDC. As the same pistons are being used is this step still needed?The block can then be returned to the machine shop for the block deck to be machined to bring the tops of the pistons to block deck level minus 0.002" to 0.005".
You may or may not also find this of some help.
http://www.theminifo...-just-building/
Cheers.
Andy.
Andy, I must have read that thread 4 or 5 times end to end now. It's a fantastic guide that I'll be using for a lot of reference. You can add me to your list of grateful forum members :)
Edited by maieth, 17 April 2013 - 06:09 PM.
