Hi, Had a little accident with the angle grinder today when trying to remove the old bump stop. Is this shock absorber still safe?
Shock Absorber.jpg 37.14K 186 downloads
Posted 28 April 2013 - 05:53 PM
Posted 28 April 2013 - 05:57 PM
doesn`t shows how deep the cut is
Posted 28 April 2013 - 05:59 PM
urm i gonna say no
Posted 28 April 2013 - 06:01 PM
for cost, id replace as soon as you can.
Posted 28 April 2013 - 06:04 PM
Its through the outer shield but it hasnt touched the inner bit
Posted 28 April 2013 - 06:15 PM
Better to be safe than sorry....not that a collapsed shock will explode like a bomb....it'll just wee everywhere!
Posted 28 April 2013 - 06:27 PM
I think the general consensus here is to change it to be on the safe side. It may last a long time but they are not terribly expensive to replace. Change both though unless they are relatively new.
Posted 28 April 2013 - 06:58 PM
i would change it aswell.
i pointed it out to tell that the picture wasn`t wreally clear, but as said before replace asap
freaker
Posted 28 April 2013 - 07:35 PM
Thanks for the advice! I will change it at the next opportunity
Posted 28 April 2013 - 07:54 PM
Posted 29 April 2013 - 04:41 PM
Must have stank grinding a chunk of rubber
We only cut metal, no rubber
Posted 29 April 2013 - 04:48 PM
Posted 29 April 2013 - 05:36 PM
Cover that bare metal on your subframe too to keep the rust bunnies at bay.
Will do
Mini Technical Sections →
Problems, Questions and Technical →
Mot Advisories On Potential PurchaseStarted by billlifferr , 12 Jun 2023 suspension |
Fitting 10” Wheels On My Mini Convertible (Spi)Started by Dalla , 29 May 2023 suspension, brakes |
Radius Arm - Reaming Or Beyond Repair?Started by Chelsea_Pete , 04 May 2023 suspension |
Correct Upper Suspension Arm Tightening Process?Started by Dakinn , 03 May 2023 suspension |
Track Rod End Thread Engagement / Adjustable Lower ArmsStarted by YankWithAMini , 02 May 2023 suspension |
