0 Gaue Power Line
Best Answer Ruckus , 09 May 2013 - 06:39 AM
Cut some strips of plastic out of a ice cream tub or something. About 2 or 3 inches 10/15mm wide.
Fold it over the cable and put a self tapper through the plastic and in to the floor or mounting holes in the sub frames.
Done. Go to the full post
23 replies to this topic
#16 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 15 May 2013 - 12:15 PM
Fair enough, haven't seen any posts about it personally but I'm pretty new here :P
Power cable will be on hold briefly while I tour the Adriatic might have a measure up and see if I have enough to run across and through the car to avoid the signal cables.
If not I'll mount a metal tube on the underside to act as conduit, it will offer far more protection than the flimsy partia length original effort either way.
#17 shivi_d92
shivi_d92
  • 228 posts
Posted 24 July 2013 - 04:37 PM
any pics of how people mounted theirs yet? interested in knowing how you guys connected it to the alternator so i know what connectors to buy
#18 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 24 July 2013 - 04:55 PM
Couple here for you, I used rubber sleeved P clips under the car and reused the alternator plug with the 0 gauge wire plus a couple of ring connectors for the starter.
http://www.theminifo...ocar/?p=2817203
#19 Brams96
Brams96
  • 2,308 posts
Posted 24 July 2013 - 09:29 PM
Done.
Did someone hack your account Joe or were you being serious? Plastic icecream tub cable holders :ohno: , outside the car :ohno:  O_O ? Not the usual high standard I'd expect from you mate.
I'd go with Freshairmini's suggestion of P clips, but the cable also needs to be protected inside some sort of sheath or conduit. If you don't want to do that then run it inside the car.
#20 shivi_d92
shivi_d92
  • 228 posts
Posted 25 July 2013 - 06:00 PM
cheers matey, still planning on running inside the car to be honest
#21 Skortchio
Skortchio
  • 1,596 posts
  • Local Club: EMC
Posted 25 July 2013 - 07:47 PM
In that case it'll look just the same with the cable on the other side of the floor pan :P
#22 shivi_d92
shivi_d92
  • 228 posts
Posted 25 July 2013 - 09:44 PM
haha pretty much! gave the alternator a quick look a month back when i was going to do the power cable, just scratched my head about how to connect the cable and left it LOL
#23 screech
screech
  • 3,136 posts
  • Local Club: Bognor rock ya mini & WSMOC
Posted 25 July 2013 - 10:18 PM
What alternator are you running?
To be wanting such a size cable you must be running a big non-mini alternator, which has a bolt on type connection? Right?
#24 shivi_d92
shivi_d92
  • 228 posts
Posted 25 July 2013 - 10:31 PM
nope just the standard alternator that comes on the Cooper SPI (70amp i believe)
