hey guys.. so i was checking and cleaning my plugs and once i was done i figured i should check the contact point gap and when i opened the cover there was black oil all over the contact point and behind it.. i didnt see much oil on the condenser unit.. owh im running a 46D 998cc and all contact points as per original.. lucas all around.. any ideas guys?
Posted 23 May 2013 - 06:55 AM
Posted 23 May 2013 - 08:26 AM
It's possible you have some wear in the shaft and bushing and oil is getting up into the main body from the engine
Posted 23 May 2013 - 09:18 AM
Crankcase pressure at a guess.....
Posted 23 May 2013 - 10:53 AM
but i have a breather on the back near the manifold.. so im not sure about the pressure but as for a worn seal it is possible is guess
Posted 23 May 2013 - 03:24 PM
Check for play for and aft in the distributor shaft thats where its coming up, either to crankcase pressure or just plain wear in the shaft bearing.
Posted 24 May 2013 - 06:47 AM
there is some play on the rod.. the one where it moves..
Posted 24 May 2013 - 01:54 PM
Check one thing first, before assuming the worst. With the engine running, remove the oil filler cap and place the palm of your hand over the hole. Disposable glove recommended at all times when risking contact with used engine oil!
If there is general suction (some pulsation due to piston movement is normal) your breather is fine, so the problem lies with the distributor. I recommend that you have it overhauled or reconditioned, with a new shaft and bearings. A worn shaft makes the timing somewhat erratic and impairs performance, fuel consumption and emissions, so having it fixed will be cost effective in the long term.
Distributor Doctor have a good reputation:
http://www.distributordoctor.com/
Edit: You could asking them to supply just the bits you need and do it yourself. I don't know if they supply individual parts but it costs only a phone call to ask.
Edited by tiger99, 24 May 2013 - 01:56 PM.
Posted 25 May 2013 - 08:43 AM
alright thanks for the tip mate.. appreciate it..
Also tagged with one or more of these keywords: electrical, engine
Mini Technical Sections →
Problems, Questions and Technical →
Trying To Find The Right Wire Harness Online...Started by mattaebersold , 22 Jul 2025 ![]() |
What Size Are These Main And Big End Bearings?Started by scottyboy805 , 19 Jul 2025 ![]() |
engine
Spi Bad Idle And 'tapping' Engine SoundStarted by Simmi Westo , 15 Jul 2025 ![]() |
Mini Rio 93 Boot Wiring IdentificationStarted by KanKanManKan , 11 Jul 2025 ![]() |
![]() Help! Water In Oil Question....Started by TerryLee , 06 Jul 2025 ![]() |
