Drum Brake Screw Won't Undo!
36 replies to this topic
#1 aelx.hopwood
aelx.hopwood
  • 32 posts
Posted 20 June 2013 - 01:29 PM
One of my rear brakes is stuck on, so yesterday I was going to take it apart and fix it.
I took the wheel off and tried to unscrew the drum, but it is rusted still.
I used a lubricant to try to relieve some of the friction between the two surfaces, but it still won't move.
Any advice would be helpful. I don't particularly want to drill it out, obviously.
#2 davidJK
davidJK
  • 185 posts
Posted 20 June 2013 - 01:36 PM
Try an impact screwdriver
#3 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 20 June 2013 - 01:38 PM
Impact scredriver.
#4 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 20 June 2013 - 01:46 PM
Moved to problems, questions & technical.
#5 Gremlin
Gremlin
  • 2,142 posts
Posted 20 June 2013 - 02:04 PM
weld a big nut to it and get a socket and breaker bar on there
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 20 June 2013 - 02:37 PM
The head of the brake drum screw is countersunk so bit of a job trying to weld a big nut on it, but hit the face with a hammer several times and if you don't have a impact screwdriver then get a stout well fitting screw driver and hit the end whilst twisting it. it it wont budge then a small chiesel and try and tap it around. Impact driver has always worked for me, never had to drill any out yet.
Edited by KernowCooper, 20 June 2013 - 02:37 PM.
#7 Gremlin
Gremlin
  • 2,142 posts
Posted 20 June 2013 - 03:08 PM
Attached File  image.jpg   50.63K   47 downloads
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 20 June 2013 - 03:21 PM
Thats a lot of work for a simple job ;D not doubting its a cure :proud:
#9 Gremlin
Gremlin
  • 2,142 posts
Posted 20 June 2013 - 03:42 PM
Welding a nut on?...... yeah...... really hard work?
#10 Yoda
Yoda
  • 1,958 posts
Posted 20 June 2013 - 03:50 PM
But when you put it all back together, the wheel wont sit square LOL
#11 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,034 posts
Posted 20 June 2013 - 03:57 PM
I have one like this which has loads of different sized bits, The big handle makes it easy to undo screws like that and alos the door hinge ones too. http://www.ebay.co.u...=item2a1688c62f
#12 lrostoke
lrostoke
  • 6,923 posts
The nut will work on 2 levels, give a better grip by being a socket head, and the heat will work as well.
But I'd try impact driver first.
I don't replace the screws, not needed, the wheel and wheelnuts hold it all on.
You could also if poss wind a couple of wheelnuts on see if it takes the pressure off the screw enough
#13 Gremlin
Gremlin
  • 2,142 posts
Posted 20 June 2013 - 04:02 PM
Oh yeah, I woul use an impact driver first, and wouldnt normally change the screws, and tightening the wheel nuts on is a good idea, if you've got open ended wheel nuts...... which I havent :(
#14 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 20 June 2013 - 05:21 PM
You have a tight brake drum retaining screw, how many here have access to a welder ? All I'm saying is its making a big job out of a little job and your picture shows a radiused bolt
#15 Ivor Badger
Ivor Badger
  • 846 posts
Posted 20 June 2013 - 05:26 PM
Get a decent small chisel and pick up the edge of the screw head and rotate it off. If that doesn't work, just drill the head off.
