Drum Brake Screw Won't Undo!
36 replies to this topic
#31 Ivor Badger
Ivor Badger
  • 846 posts
Posted 22 June 2013 - 11:14 AM
I guess some can be stubborn...Not had a problem with a drum screw, but had the door hinge screws resist impact driver, drill bits burning them out...resorted to welder on them
It's the heat of the welding that freed the screw, not the technique of welding on the bolt. The only way to get them out for years was to put the gas welding torch on them, a bit of diesel to cool and they unscrewed.
Just do what everyone did for years, drill the head off.
The screw is there to stop the drum falling off. It must be in the factory during production, as they would never fall off changinfg the wheels.
#32 Gremlin
Gremlin
  • 2,142 posts
Posted 22 June 2013 - 11:24 AM
1st page, 3rd post from the bottom.
#33 Ivor Badger
Ivor Badger
  • 846 posts
Posted 22 June 2013 - 11:37 AM
Oh yeah, I woul use an impact driver first, and wouldnt normally change the screws, and tightening the wheel nuts on is a good idea, if you've got open ended wheel nuts...... which I havent :(
While an impact driver will work occasionally, the head will strip most times. So try the ID if you have one and the go for the drill.
I take it the idea of the wheel nut tightening is to do so with the wheel removed to push the drum on relieving the load on the screw. So what about the plain bit of stud potruding from the drum that will stop the nut bottoming oin the drum?
#34 Gremlin
Gremlin
  • 2,142 posts
Posted 22 June 2013 - 03:21 PM
I didn't have te idea, I was just agreeing, I haven't actually fully looked in to it. And if you push the impact driver into the head of the bolt properly, it won't round unless you are really special
#35 BusheyTrader
BusheyTrader
  • 481 posts
  • Local Club: Nope
Posted 22 June 2013 - 06:00 PM
I used an impact driver to free off both rear drums yesterday.  It didn't round the screw head and they were both freed in seconds
#36 Ivor Badger
Ivor Badger
  • 846 posts
Posted 22 June 2013 - 06:20 PM
Well lucky you, hope you've bought a lottery ticket. :highfive:
#37 aelx.hopwood
aelx.hopwood
  • 32 posts
Posted 22 June 2013 - 07:20 PM
Impact driver bought! Thanks for your help, everyone.
No doubt I'll be back soon :P
