Drum Brake Screw Won't Undo!
36 replies to this topic
#16 Gremlin
Gremlin
  • 2,142 posts
Posted 20 June 2013 - 05:57 PM
Welding a nut on?...... yeah...... really hard work?
You have a tight brake drum retaining screw, how many here have access to a welder ? All I'm saying is its making a big job out of a little job and your picture shows a radiused bolt
What do you mean by radiused bolt?
#17 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 20 June 2013 - 06:00 PM
Where you have marked weld on the 2 points on your picture looks like the bolt has a radius to infill onto the brake drum screw with weld
#18 mini13
mini13
  • 3,811 posts
Posted 20 June 2013 - 06:27 PM
your all making this far harder than it needs to be,
just drill the head off,
#19 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
  • Local Club: Surabaya Mini Club
Posted 21 June 2013 - 03:44 AM
Yes, if you try it with a stick set. You might have more luck with a MIG set.
If you like struggling instead of using an impact driver which I have never had failed on a brake drum retainer screw - then you might weld a washer on first, then a nut on to the washer.
I'd personally go and by a £4-99 impact driver myself.
#20 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 21 June 2013 - 03:47 AM
Why? Did the impact driver not work?
#21 Gremlin
Gremlin
  • 2,142 posts
Posted 21 June 2013 - 07:03 AM
If you read what I have said, you would see that I always go to the impact driver first, but if all else fails, weld a nut to it
#22 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 21 June 2013 - 10:37 AM
weld a big nut to it and get a socket and breaker bar on there
I did read what you said.
Each to his own, but I've never had one resist the driver, and if it did, it would get drilled before I got the welder out.
Edited by Captain Mainwaring, 21 June 2013 - 10:38 AM.
#23 lrostoke
lrostoke
  • 6,923 posts
Posted 21 June 2013 - 10:48 AM
I guess some can be stubborn...Not had a problem with a drum screw, but had the door hinge screws resist impact driver, drill bits burning them out...resorted to welder on them
#24 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 21 June 2013 - 11:00 AM
Get yourself a few solid carbide TiAIN coated drills - they will munch themselves through pretty much anything.
#25 seancv1
seancv1
  • 187 posts
I'd probably drill the head first then mole grip the remains off after removing the drum welding a bit on does seem a bit excessive perhaps a last resort.
#26 seancv1
seancv1
  • 187 posts
Posted 21 June 2013 - 11:02 AM
Obviously after the impact driver solution,, I'd probably replace the screw afterwards too its surely there for a reason ! :-)
#27 rally515
rally515
  • 3,848 posts
Posted 21 June 2013 - 11:12 AM
Forgive my ignorance but couldn't you just undo the hub nut and stick it in a vice and use the technique i did on a drive flange screw a while back now ? (picture available)
#28 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 21 June 2013 - 11:20 AM
You could put the whole car on it's side and find a big universal mill :-) but I think the OP is looking for a quick way out.
#29 Gremlin
Gremlin
  • 2,142 posts
Posted 21 June 2013 - 11:39 AM
Not that bit, the part where I said I would always use an impact driver first, then resort to a welder, then drill it out, because if you try to drill it out before you weld it, you wont have anything to weld to
#30 Captain Mainwaring
Captain Mainwaring
  • 1,712 posts
Posted 22 June 2013 - 11:01 AM
Hehehe...That's where I'm getting confused - I can't find that bit.....
