Hi,
I've put down the angle grinder and welding torch briefly to strip down the rear subframe. As expected a number of the bolts sheared in the captive nuts despite heat and WD40 etc but its these ones that are causing problems at the moment.
Radius arm stub axles - won't undo from the subframe. I've tried the double locknut method on the free end but nothing's budging. According to Minispares website the threads are handed but I've allowed for that.
http://www.minispare...64.aspx|Back to
Rear Subframe Support Pin - won't budge. If there's a specific two - pin tool that fits on the outer part I haven't found it. There's nothing to grip on otherwise. Do I attack it with a large mole wrench, stilson or similar?
http://www.minispare...MS.aspx|Back to
I've tried the search function on the forum but no luck as yet on finding a solution.
Thanks,
Adam
Edited by BusheyTrader, 22 June 2013 - 09:11 AM.
